element14's The Ben Heck Show
Forum pcb drill msachine
  • Subscribers 32 subscribers
  • Views 778 views
pcb drill msachine
vishnuchuncha
vishnuchuncha over 12 years ago
hello ben,
your tutorials are awesome , can you please make tutorial on how to make pcb drilling machine using dc motor at home
  • element14jamie
    element14jamie over 12 years ago +1
    Hello Vishnu, Welcome to the element14 Community, we hope you enjoy it. I will move this over to the Ben Heck Show area as it is a better fit. Thank you, Jamie
  • element14jamie
    Hello Vishnu,
    Thank you,
    Jamie
  • vishnuchuncha
    Sir its been a long time since i dint still find a video by ben regarding how to make pcb drill machine using dc motor
  • kidiccurus
    kidiccurus over 12 years ago in reply to vishnuchuncha
    A computer controlled PCB drilling machine is just a CNC router. Ben has made one of these in the past.
  • vishnuchuncha
    vishnuchuncha over 12 years ago in reply to kidiccurus
    hello samuel, actually i dont want to use cnc router because its expensive and there are many hobbyists who cant spend much money, so please provide any resource regarding a pcb drill machine
    e14 Contributor over 12 years ago in reply to vishnuchuncha
    I ordered a micro drill press that holds a dremel tool. They can be had for about $25 on E-Bay plus the cost of the Dremel. There are small drill bits for it and you simply put the board up on the tool and drill the holes.
    I wrote about cutting my own circuit board on my web site, in Part 3 there is a picture of it.
    www.xganon.com
    Hope it helps.
  • mysticmindset
    mysticmindset over 12 years ago
    I used a dremel and a perf board as a template to line up the drill. If you are talking about using dc motors to move the gantry system i would shy away from that as you would most likely need some sort of feedback to tell the controller how far it moved. I have been putting some thought into a gantry system for a dvd burner laser I'm working on and was thinking a ramps kit would be a good controller as its fairly cheap and comes with steppers. I have a bunch of old okidata dot matrix priters i was going to use for the slides, they have thick slides and bearings pressed in blocks with threaded holes.
