element14's The Ben Heck Show
Forum Modding an old laptop in to a regular screen.
  • Subscribers 30 subscribers
  • Views 542 views
So I have a broken(the graphic chip is broken) laptop, and I was wondering If it's possible to take the screen off and mod it, so you would get a regular LCD screen with an input plug (vga,dvi,hdmi, doesn't really mater at this point). I was thinking that the LCD screen in a laptop is basically a regular LCD plugged in to a graphics card, even if it use a ribbon cable. So what I want to do is take the screen off, from the broken laptop, and mount some kind of plug on to it, so it could work as a regular screen, separated from the rest. My question is: is this something easily done, or there is no point om trying because of how complicated/ costly it would be ?
  • colecago
    colecago over 12 years ago in reply to e14 Contributor +1
    You will need to power it. You might be able to use the laptop power brick. Look at the pictures in the ebay link and they kind of show things hooked up.
  • colecago
    Depends on the internal connections of the laptop, they usually are LVDS and you can use an LVDS board to get the functionality you want
    http://www.ebay.com/itm/LCD-Controller-Board-DIY-Kit-RTD2270L-Driver-LVDS-Inverter-Turn-LCD-to-Monitor-/110925504614?pt=US_Server_Boards&hash=item19d3ace066
    e14 Contributor over 12 years ago in reply to colecago
    So it is possible, I will know what's inside, when I actually open it up. One more question, the LVDS will function more or less as an input for the signal, and what about the power to actually turn it on, since it was previously powered from the laptop motherboard, or will the LVDS also supply the power to the screen ? The laptop is an HP Pavillion dv6000 series if that will help.
  • colecago
