element14's The Ben Heck Show
Forum Burglar Alarm to Door Buzzer Using a Monostable Circuit
  • Replies 32 replies
  • Subscribers 31 subscribers
  • Views 4429 views
  • monostable
At work we are currently using what I suspect is a burglar alarm as a door buzzer. It's inappropriately loud to have buzzing the entire time the door is ajar (from barely open onward), as we're a motel and it's frankly obnoxious. However in order to hear people come in from the basement, it's what the folks in charge decided to use. I would very much like to create a monostable circuit so it buzzes for a small amount of time then turns off until the door is shut again, re-arming the buzzer. The buzzer works using a momentary switch that is pressed when the door is shut and released when the door is open. This switch is connected to what looks like a transformer core, and the device also plugs into our AC outlet.
I have looked at circuits online, but even using a few simulators I was unable to produce results like I wanted. Can I have some advice? I'm new to electrical engineering.
    jw0752 over 11 years ago +1
    Hi Simon, I have set up a mock up of an improved circuit which allows the door switch to close and remain closed. The components that I have selected for C1 and R1 give a time of approximately 5 seconds…
    jw0752 over 11 years ago in reply to e14 Contributor
    Keep in mind when getting the power supply for the circuit that the max supply for the 555P is 15 volts. If you go higher than this you will need to incorporate a voltage regulator.
    e14 Contributor over 11 years ago in reply to jw0752
    Yeah, that's why I limited my search to supplies between slightly over 12V to 15V. Thankfully there were several to choose from.
