element14's The Ben Heck Show
Forum Screw posts in 3d printed parts
  • Subscribers 30 subscribers
  • Views 840 views
jaskamakkara
jaskamakkara over 8 years ago
Perhaps I have missed it from a previous video, but I was wondering how you make your screw posts in 3d printed case parts, for example.
Do you print the screw post as a solid lump then drill it out afterwards? Or do you print it hollow then tap it out to match your screws? What's the best way?
It always seems that your screws go into the posts very easily and nicely and I was just curious.
Thanks.
  • makerkaren
    makerkaren over 8 years ago +2 verified
    Ben does this a couple different ways. Sometimes he will print solid and simply drill it out. Frequently, he'll print the hole the diameter of the shaft of the screw, but not of the threads. This way the…
  • jaskamakkara
    jaskamakkara over 8 years ago in reply to makerkaren +1
    Thanks for the information, Karen. Appreciate it!
  • makerkaren
    0 makerkaren over 8 years ago
    Ben does this a couple different ways. Sometimes he will print solid and simply drill it out. Frequently, he'll print the hole the diameter of the shaft of the screw, but not of the threads. This way the threads of the screw dig into the plastic, but there is enough plastic missing to accommodate the shaft of the screw. If that's not enough, Ben does have a tap. I will say that when he prints with a hole, he does often have to go back with a drill bit to remove a little more material to make the hole size more precise as the shrinking of the filament can be a bit unpredictable.
  • jaskamakkara
    0 jaskamakkara over 8 years ago in reply to makerkaren
