element14's The Ben Heck Show
Forum Activate BJT with Digital HIGH
  • Replies 7 replies
  • Answers 3 answers
  • Subscribers 31 subscribers
  • Views 866 views
  • hardware
nbuuck
nbuuck over 15 years ago
Hi all. It's been a while since I studied transistors and I'm having a bit of trouble adapting my needs to the theory of transistors. Specifications for transistors detail the voltage across combinations of the collector, base, and emitter of the transistor. However, my need and thought process is based on the indepentent voltage on each pin of the BJT. My need is to switch a +12V supply completely on or off (trickle current is not a problem, though; we're not being idealistic) using a digital HIGH on the base (I'm planning on using an Arduino Uno, so if someone knows the characteristic voltage of a HIGH on the Uno's digital I/O pins, assume approximately that). Is a BJT appropriate for my needs? Can you think of or suggest a BJT that approximately meets these specifications?
  • Catwell
    0 Catwell over 15 years ago
    You might want to use a relay that completely cuts off the input power instead. Even if you use a BJT, some power will leak through. Usually it is not enough to cause any issues, but I personally like to cut the power completely off. (Safety issues)
    Is this 12V a DC source?
    Cabe
  • nbuuck
    0 nbuuck over 15 years ago in reply to Catwell
    Cabe,
    Thanks for your suggestion; I like it! This is for an automotive application, and given the popularity of relays for in automotive applications, I had considered it, but didn't really give it as much consideration as I should have, so thank you. That said, it is indeed a 12V DC source.
    - Nathan
    0 e14 Contributor over 15 years ago
    You can use opto couplers. PS7206-1A-E3-APS7206-1A-E3-A can handle 28volts, 600 ma for my application. The switching speed would be better than the relay. A BC547 NPN should work with your 12 volt source, but it can dissipate a lot less power. Alternately you can use ULN2803
  • nbuuck
    0 nbuuck over 15 years ago in reply to e14 Contributor
    krooks,
    The PS7206-1A-E3-APS7206-1A-E3-A that you mentioned looks like another promising alternative. It's particularly adventageous for my application because of the small form factor.
    My decision on which switching component I'll use is pending a test of the normal operating current of the system that this will supply and some other minor details.
    Thank you both for your excellent input.
    You can use this particular part as well : TN2-L2-4.5VTN2-L2-4.5V. You do require a driver for it though. We use PCB mounted relays with contact rating of 1amp from OMRON and O/E/N. You can try those manufacturers as well.
  • Catwell
    What is the application? Knowing this will help pick a good option for you.
    Cabe
    Surely a simple dropdown resistor on the base would suffice?
