element14's The Ben Heck Show
Forum Cheap 3D Printer
  • Subscribers 32 subscribers
  • Views 601 views
Cheap 3D Printer
tim12
tim12 over 13 years ago
Hi to all,
I would be very grateful if you answer my questions?
I have decided to buy a printrboard from ebay and several stepper motors:
Printrboard£    77.59 1http://www.ebay.co.uk/itm/PrintrBoard-Electronics-for-PrintrBot-Prusa-Mendel-or-your-RepRap-project-/271019776730?pt=LH_DefaultDomain_0&hash=item3f1a099ada
5V Stepper Motor£       9.60 3http://www.ebay.co.uk/itm/DC-5V-Gear-Stepper-Step-Motor-with-ULN2003-Driver-Board-4-Phase-Unipolar-/140956394738?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item20d1a7e4f2
Total
£    87.19
For the hot end, I am using the 3mm ubis hot end.  However, do any of you know which hot end is better - ceramic or cartridge? Thanks
Please may you tell me how I can be able to wire up the hot end and the stepper motors to the printrboard? Thanks and do I need the motor driver with it?
NB: I am using Ben Heck's Design forthe Double Decker 3D printer
Here is a stepper motor taken apart Canon MP190 Printer:Can I use this motor for the printer? Will the driver work. It has four wires.
http://s3.postimg.org/vo1q8w5zj/P1020963.jpghttp://s3.postimg.org/3p7ki14cv/P1020964.jpg
Thanks again
Timimage
  • Nate1616
    Nate1616 over 13 years ago +1
    Hey Tim As for which hotend is better that depends on who you talk to. They are using different technologies to heat up. The ceramic hot end uses a nichrome wire wrapped around the hotend with ceramic…
  • Nate1616
    0 Nate1616 over 13 years ago
    Hey Tim
    As for which hotend is better that depends on who you talk to.  They are using different technologies to heat up.  The ceramic hot end uses a nichrome wire wrapped around the hotend with ceramic paste covering it.  Its similar to a toaster.  The cartridge type is similar to the power resistor hotend but a little more robust.  I typically go with the cartridge or power resistor type hotend but again that is just my preference.  One issue people have with the power resistor is that the resistor can burn out faster than for say if you were to use a ceramic hotend.   I would check out the printrboard documentation or its wiki page for all the hookups you will need(extruder, motor, endstops, heatbed).  As far as do you need a driver the answer is no.  The printrboard has these drivers integraded.  The motors will work but Im not sure you will get the torque out of them that is needed.
    Nate
  • tim12
    0 tim12 over 13 years ago in reply to Nate1616
    Thanks loads!
    I'm sorry but I can't find the correct/helpful answer button!
    TIm
    I'll look later asap
  • Nate1616
    0 Nate1616 over 13 years ago in reply to tim12
    Hey Tim
    I would look at getting something similar to this for your stepper motors http://www.lulzbot.com/?q=products/nema-17-stepper-motors
    as this is a typical.  Some will require/recommend you use nema 23 but most repraps use nema 17.
    Nate
  • benheck
    0 benheck over 13 years ago
    You know I actually got that same assembly from a surplus store and tried making a plastic extruder out of it. It worked, but the motor got very warm.
    If you can get Nema 17 steppers for $15, just use those. They work, and they have standard mounting.
    You can waste a lot of money trying to do things cheaply.
  • rhyse302
    0 rhyse302 over 13 years ago in reply to benheck
    Did you check Makershed or Newark?
