element14's The Ben Heck Show
Forum Using IR to control a motor
  • Subscribers 30 subscribers
  • Views 649 views
  • help
  • programming
  • ir
  • dc
  • motor
I have just started with IR (also a few other things go easy) and was wandering if I could control a DC motor with an remote I got in a kit, also I need help with the circuit mostly just wiring IR receiver Ièm very confused with certain things also how would I program the motor for when the button on the remote is pushed to turn on then stay until it is pushed again.
  • Blacksheep32
    0 Blacksheep32 over 13 years ago
    Do you have a microcontroller you are using for this project?  I have seen some neat tutorials for using an arduino to read IR commands and then once you know what the remote control is sending, the arduino can control the motor.
    0 e14 Contributor over 13 years ago in reply to Blacksheep32
    I have an Arduino UNO
    also sorry for the random e with accent my computer likes changing languages
  • Blacksheep32
    0 Blacksheep32 over 13 years ago in reply to e14 Contributor
    I'm only going to throw the concepts out there and let you have at it.  I have not done a project like this before.  End caveat.
    First you need to read what the IR remote is saying, there are many turorials on the web for this: example
    http://www.instructables.com/id/The-Easiest-Way-to-Use-Any-IR-Remote-with-Ardiuno/
    Then you need to modify that sketch to control your motor, because you haven't listed any specs on the motor other than DC, I can't point you in to many places but there are many ways to control the motor using the Arduino: example
    http://playground.arduino.cc/Main/DCMotorControl
    Good luck and show us what you make when you're finished!
    Thanks I would specify other specs on the motor but there are none that I
    can find
  • Blacksheep32
    If it's a small motor (fits in your hand) chances are these tutorials will be sufficient.
