element14's The Ben Heck Show
Forum Is it possible for a copy of Windows to run on a Raspberry Pi?
  • Replies 22 replies
  • Subscribers 33 subscribers
  • Views 3620 views
  • viewer
  • hack
  • portable
  • build
  • episode
  • build_challenge
  • idea
  • viewer_challenge
  • challenge
  • ben_heck
  • heck
  • ben
  • show_idea
Hello i was wondering if it was possible to run either windows 8 or windows xp on a Raspberry Pi model B 512mb.
ever since i bought my Raspberry Pi i was always thinking of if my thought would be possible. Being a raspberry Pi it does not have the function to boot off a memory stick to install a copy of windows therefore that stopped my train of thought.
please someone will you be able to help me with my problem and either do a well documented walkthrough on a blog or would someone be able to make a video dissussing the topic and how to acheive this... thank you lloydpheasant.
  • SGarciaV
    SGarciaV over 13 years ago +1
    I agree with Coder27. Since Raspberry Pi runs Linuz the question could changed to "Can Windows xp/8 run on Linux?". Surprisingly, the answer to this yes, but with certain reservations. The hardware that…
    e14 Contributor over 13 years ago in reply to e14 Contributor +1
    One big issue is that MS has a requirement that Arm devices running Windows8 must run UEFI firmware and have secure boot enabled, I'll refrain from lighting that particular flame-fest here, but it should…
  • hawkeyethehacker
    hawkeyethehacker over 12 years ago in reply to e14 Contributor +1
    As someone who works on embedded platforms I have two things to say: Please, spell correctly so other people can understand you We know computers work on binary, however the problem is how said computer…
    Oh cool, I didn't know that.
    If you could get ahold of the ARM version of Windows 8 you could probably run it straight on the Pi, the problem is it is only available to OEMs. This has been mentioned on the Raspberry Pi website. That leaves x86 emulation and remote desktop. Emulation would be horribly slow on any versoin of Windows XP and up. You could brobably run Windows 95 through DOS Box or something like that, but remote desktop is probably the best option if you already have a computer with Windows running on it and a decent network speed.
    Could you though ?  Start with simple questions like whether any drivers for the Pi's unique hardware are available, does the GPU support DirectX 10 for example. Then move on to the Pi not having UEFI, so you're unable to even boot Win8.
    That's all before you work out if Win8 will even run on an ARMv6.  Drivers/UEFI could probably be fixed by the RPF or Broadcom if they felt it was worth the investment.  Should Win8 require NEON or something else that's not in ARMv6 then you're stuffed, only MS could fix that.
    There's a post here http://social.msdn.microsoft.com/Forums/en-US/winappswithnativecode/thread/72588182-d22c-417e-836f-77ddec78ee38 from a MS employee that suggests win 8 on Arm will require NEON, but it's difficult to know for sure as there doesn't appear to be an official list of hardware requirements.  Likely due to it only being available for OEM's to preinstall on their hardware, there's no need for this sort of info to be available.
    Anyway, in the RPF FAQ and forums:
    http://www.raspberrypi.org/faqs
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=2&t=2557
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=30&t=22164
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=7&t=2898
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=56&t=7231
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=2&t=5392http://www.raspberrypi.org/phpBB3/viewtopic.php?f=24&t=5331
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=41071
    Worth a read for entertainment value, but not much else, and just put 'windows 8' into their search box for a ton more.
    TL;DR; version, when the folks in the RPF who designed the Pi say 'No'....
    No but there is a YouTube page showing a software called magnum pi so search on YouTube for windows on a raspberry pi and choose the university of Cambridge
    Lets be clear.  That YT video is not showing Windows running on RPi.
    It's showing Windows running on some other computer, which is networked to RPi.
    0 e14 Contributor over 12 years ago in reply to SGarciaV
    you are all rong as a programer in it i understand that operating systems work on 01 (bianary) if you downlode mac you run 01 to run funchons linik 01 and windows 01 if you were to use windows you have to make it so its on the harddrive by the logic you are explaning you can have linix on a mac and mac cant read webpages that are in windows html and linix cant script for a windows so you ship is bull crafp kid find some one else to talk to it may tack yeasrs but find a emulater that runs on the rasberian and makes a program that acts like windows 7 it adds a exer os for you and you can run it in your hot line to save cpu and cpu is rong it will only run wut its got to get more cup just get a bigger hard drive for example 8 gb isent enuff get a 64 gb then a tarabight external hardrive to confinscat for the lack of ran and your good
    Ok sorry my bad im only 14 and i now understand that it was a client that was ported through a master windows server on the network sorry.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    No worries Hayeden
    Outside of the basic differences of which some are listed above
    it often comes down to the resources. Look at the minimal requirements for Windows 8, now compare to the specs of the PI. Even if the CPU, Hardware and everything else was compatible (Which it is NOT)  it would take so long to boot and do anything it would not be worth it. The best you could hope for is to use it as a remote console to a windows desktop that could be anywhere in the world. I have successfully used android, IOS and other mobile devices in such a scenario. but to run windows locally on the PI... no way, in an emulator... do you have a year to wait for it to boot image
  • kidiccurus
    0 kidiccurus over 12 years ago
    Actually, with a lot of work, it is possible to run a very striped down version of xp on a pi. I do not recommend it though, it is a huge pain to set up and doesn't work properly because of all the things that need to be removed. As a technical exercise it isn't worth wasting your time
  • hawkeyethehacker
    0 hawkeyethehacker over 12 years ago in reply to e14 Contributor
    1. Please, spell correctly so other people can understand you
    2. We know computers work on binary, however the problem is how said computer translates that from Assembly/C/C++/what-have-you into binary code. Everything you have said is incorrect. Also, there is no such thing as "Windows HTML". HTML is a markup language that browsers are built to read, and that includes Safari, Firefox, Chrome, IE, etc. Unless you are talking about ASP.NET, which still returns HTML, that is incorrect. Second, hard-drives cannot supply RAM, but they can supply a small amount of swap space. Third, why bother with a program that emulates Windows 7? It would takes years to do and it would not be worth it. In addition, the Pi would not be up to such a task. (See point 2).
    A final point - if you want to argue against this, go ahead. Because me and a few other people on this community CAN prove you wrong. The way you spoke to the person here trying to learn was downright rude, and your mistakes have been pointed out.
    TL;DR, do not tell someone to "find someone else to talk to" when you yourself do not know about the subject.
