element14's The Ben Heck Show
Forum Is it possible for a copy of Windows to run on a Raspberry Pi?
  • Replies 22 replies
  • Subscribers 33 subscribers
  • Views 3624 views
  • viewer
  • hack
  • portable
  • build
  • episode
  • build_challenge
  • idea
  • viewer_challenge
  • challenge
  • ben_heck
  • heck
  • ben
  • show_idea
Hello i was wondering if it was possible to run either windows 8 or windows xp on a Raspberry Pi model B 512mb.
ever since i bought my Raspberry Pi i was always thinking of if my thought would be possible. Being a raspberry Pi it does not have the function to boot off a memory stick to install a copy of windows therefore that stopped my train of thought.
please someone will you be able to help me with my problem and either do a well documented walkthrough on a blog or would someone be able to make a video dissussing the topic and how to acheive this... thank you lloydpheasant.
  • SGarciaV
    SGarciaV over 13 years ago +1
    I agree with Coder27. Since Raspberry Pi runs Linuz the question could changed to "Can Windows xp/8 run on Linux?". Surprisingly, the answer to this yes, but with certain reservations. The hardware that…
    e14 Contributor over 13 years ago in reply to e14 Contributor +1
    One big issue is that MS has a requirement that Arm devices running Windows8 must run UEFI firmware and have secure boot enabled, I'll refrain from lighting that particular flame-fest here, but it should…
  • hawkeyethehacker
    hawkeyethehacker over 12 years ago in reply to e14 Contributor +1
    As someone who works on embedded platforms I have two things to say: Please, spell correctly so other people can understand you We know computers work on binary, however the problem is how said computer…
    The first question to ask is "do I need Windows?"  A lot of software you might want to run on a Raspberry PI has already been recompiled for the system and will quite happily run natively under various distros of Linux.  In other cases it might also be possible to recompile it yourself.
  • david98xp
    0 david98xp over 12 years ago
    Get a Minnowboard MAX!
    From $99 board only.
    1gb/2gb RAM
    1.44ghz single core/1.36ghz dual core
    Micro SD-USB 2 and 3-I2C-SPI-PWM-8 GPIO-64 bit and 32 bit(switch at any time)
