element14's The Ben Heck Show
Forum Wireless
  • Answers 2 answers
  • Subscribers 33 subscribers
  • Views 736 views
Wireless
I'm trying to make a car/boat thing with a nerf gun on which needs at least 10 channels. I want it remote controlled from a computer and want a live camera feed. I thought Rasberry pi with cam shield and 3g modem. But the problem is, I need at least 2 of the outputs to be PWM and I'd like the the cam feed to be at least 24 fps which ben didn't seem to get from his dog treat dispenser pi.
  • gihu
    0 gihu over 13 years ago
    I also want to do something similar, car with live cam, remote controlled. But I was thinking on using STM32F board.
    For the cam, there is the OV7670 (http://dx.com/es/p/ov7670-300kp-vga-camera-module-for-arduino-147742) which seems to feed 640x480 30fps, which I want to try, if it doesn't fit for your project I think there is MT9M111, which seems to have better characateristics.
    About PWM, try to use this:
    http://www.adafruit.com/products/815, up 16 PWM controlled trought I2C.
    Hope it helps,
    Miguel
    0 e14 Contributor over 13 years ago in reply to gihu
    noob question but can u control I2C or composite video output trough an xbee?
  • colecago
    0 colecago over 13 years ago in reply to e14 Contributor
    You could get a usart based PWM module, as for video over zigbeem I don't think so.  You'd basically be sending it over serial which I don't think is a feasible option.  I recommend you look at FPV systems for RC vehicles.  Then just make a custom controller that has both your electronics for control and a cheap FPV system for video.
    EX http://www.ebay.com/itm/FPV-5-8G-200mw-RC-5808-Receiver-TS58200-Transmitter-Rceiving-System-/161085514830?pt=Radio_Control_Parts_Accessories&hash=item258171e44e
    well then I'll to use 2 xbees and  RC car FPV system.
  • benheck
    0 benheck over 13 years ago
    Yes a standard remote control car/plane RF system sounds like a good bet.
  • ckraft
    0 ckraft over 13 years ago
    Part of the reason we got a terrible frame-rate with the Dog Treat Dispenser is because of the problematic implementation of USB on the Raspberry Pi. I've acquired a few camera modules and intend to re-try the stuff we did for the show using the camera module. It should give much better frame-rates.
    Sending the video over another different channel is a good suggestion. Some people will use WiFi or like Colecago mentioned a special video system to send the video separately. Heck even the military uses different channels/frequencies for their drones sending video on one frequency and control data on another.
