element14's The Ben Heck Show
Forum Viewer Question: Simple Pinball
  • Subscribers 32 subscribers
  • Views 779 views
  • pinball_machine
  • hack
  • hardware
  • build
  • pinball
  • idea
  • viewer_question
  • question
     Does anyone know if it is possible to buid a simple pinball machine with only a small microcontroller? The raspberry pi can act as a microcontroller, and I was wondering if it could run from the Pi. If not, could it run from an arduino? The machine would be very simple and would use LED's or a 2-digit display instead of a DMD or an LCD. The switches on the board would just add another led to light up, or for a couple more numbers would add on the display. Is this possible? I've been wanting to do this project, and I want to know if it can be done.
-Nick
  • colecago
    0 colecago over 13 years ago
    Ben's board uses a chipkit which is Arduino compatible.  It does use another processor, a parallax, which does the Audio and DMD.  So I don't see why you couldn't just do it with the Arduino and no parallax processor if you offload the Audio and Video onto the Arduino, which wouldn't be so hard if using a small character display.
  • ckraft
    0 ckraft over 13 years ago in reply to colecago
    He could also run the whole thing off the Parallax Propeller which is what Ben's first pinball machine did.
    To the point about the Raspberry Pi, its a neat device but it is not a microcontroller and cannot act as a microcontroller. There's a specific difference between the devices like that used in the Raspberry pi, which is basically a moble processor, and the microcontroller in an Arduino which is designed for embedded real-time operations.
  • benheck
    0 benheck over 13 years ago
    There's a DIY pinball platform called P-ROC which replaces your old pinball machine electronics, or lets you build a new one.
    It needs a Linux PC to control. People have successfully used the Raspi for this.
    0 e14 Contributor over 13 years ago in reply to benheck
    Ok, cool! I have a raspberry pi and I will probably use it!
