element14's The Ben Heck Show
Forum Noob questions about 3D printer build
  • Subscribers 29 subscribers
  • Views 338 views
  • build
  • episode
  • idea
  • ben_heck
Ben, I just discovered your show on YouTube [Build a 3D Printer...] revisited.
I have a few questions about your build-
1. Power supply- is it a rechargeable battery or direct plug in?
2. The SD Card- could this be modified to accept multiple format removable storage? (USB, micro SD, etc)
3. What case materials could/should be used and pros/cons?
4. Could a rooted andriod device be used for a control panel, or is there some other touch screen option?
5. Have you addressed any aesthetics for this build?
6. What about a filament feeder- perhaps a swing out arm to hold the spool?
7. Is there any way to "automate" the Y axis tray movement for closure?
Thanks and great builds!
  • colecago
    0 colecago over 13 years ago
    1 - I believe its a computer power supply so direct plug in, no battery
    2 - Micro probably with an adapter, USB no, the SD card capability was built into the printer firmware and I don't think any of them support USB flash drives
    3 -
    4 - Yes, people are doing things like this, you'd might need to modify the code a little (for the different serial port) but an android phone can send serial commands over bluetooth and depending on your control board maybe you can toss a bluetooth module on there
    5 -
    6 -
    7 - Yes you could either mod the firmware to add a button to do a specific movement, or you can call up a gcode "pack" file from the SD card to have it return to a packable position
