element14's The Ben Heck Show
Forum Battery level driven outlet
  • Subscribers 30 subscribers
  • Views 343 views
  • build_challenge
Hi!
I have a laptop and I use it several hours a day in the same place.  I’m always trying to disconnect the power source when the battery is full and connect it when the battery is reaching a low level in order to extend the battery life.
I’m thinking on build a battery level driven outlet. It would read the battery level of the laptop through the USB port and use this measure to connect and disconnect the power source –using a relay-  in order to match the optimal charge curve of the laptop’s battery.
I know it would be easier to take away the battery but I use the laptop in different places with/without outlet and it would be very annoying.
How would you build it? What would be your solution to interface the microcontroller and the laptop?
I’m watching the program from Spain. Congratulations for your amazing gadgets!
    0 shabaz over 12 years ago
    Hi Carlos,
    This thread addresses the topic. The summary was that it is better to just let the laptop hardware manage things (it will internally disconnect).
    0 e14 Contributor over 12 years ago in reply to shabaz
    Thank you so much!
