element14's The Ben Heck Show
Forum Stepper Motor Troubleshooting
  • Replies 44 replies
  • Subscribers 33 subscribers
  • Views 7348 views
  • help
  • 3d
  • me
  • tags
  • stepper
  • stuff
  • help!
  • printing
  • motor
  • heck
  • ben
fuzion_reaktor
fuzion_reaktor over 12 years ago
Hello, my name is Peter R and for the past several months I have been building a 3D printer. I have the frame and everything done, but I consistently run into the issue where my stepper motors run erratically; when I issue a movement command they change direction at random, move in unpredictable spurts, clank, grind and make weird noises--and that's if I'm lucky enough to get them running at all. They appear to be uni-polar motors, and I have wired their four wires in as many orientations as possible and still get the same issue? Is this a board problem, or the motors themselves?
The motors are 17H249-02S motors, manufactured by Xuquan motor, but there is little documentation on them on the internet as far I have found.
Many thank to whoever can answer this.
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to D_Hersey +2
    Huzzah (yes I say huzzah) I have inadvertently solved my problem. My end-stops were wired improperly so the control board thought that they were closed. Thus my motors could never move in the direction…
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to kidiccurus +1
    Motors, yes are a plugging in problem. This is just weird. But switching the two works and I have successfully printed a small misshaped cube...Progress...
  • ootbrobo
    0 ootbrobo over 12 years ago in reply to D_Hersey
    More about the relationship of micro-stepping and torque capability
    http://www.micromo.com/microstepping-myths-and-realities
    More about the relationship of speed vs torque
    Speed - Torque Curves for Stepper Motors
  • D_Hersey
    0 D_Hersey over 12 years ago
    This is why the servo motor remains so popular with CNC.  They have to use PID, but it gives 'em a better control picture when going fast.
  • fuzion_reaktor
    0 fuzion_reaktor over 12 years ago in reply to D_Hersey
    OK, I'm kind of a noob at this as it i m first printer and first time playing with stepper motors, but I think I understand most of what you have written. However I don't have a oscilloscope or anything of that nature to test with. My most advanced tool is probably my ten year old multimeter. To answer your questions, I really don't know what the major specs of my motors are as I cannot find proper documentation on them. I have run my motors at varying amperage when testing them as that is the only thing I can adjust on them. They are listed at 1.8 amps online. I don't know their voltage, though I would assume they are just generic motors with a generic voltage. I have played with every physical switch I can find and every software setting I have and it still does not function. All I really know is that the people that I bought my kit from have verified that these motors and board combo work together, and for some reason mine wont. I don't mean to sound annoyed/complaining or anything if  I am coming off that way, but I am a fish out of water.
  • D_Hersey
    0 D_Hersey over 12 years ago in reply to fuzion_reaktor
    What size (NEMA) are the motors, what is printed on them?
  • D_Hersey
    You have a right to your feelings.  This industry has ripped me off so many times I am in a state of perma-rage with it.  I looked at your schematic, for some (truly curious) reason they cross-connect the out1 coils on the output driver.  Does your motor connector correct this?
  • fuzion_reaktor
    First off, very quick response, thank you. Second; the motors are nema-17 size, what is printed on them is '17H249-02S Xuquan motor' and a production date '2014.02.20'.
  • fuzion_reaktor
    0 fuzion_reaktor over 12 years ago in reply to fuzion_reaktor
    Are you looking at the schematic for the baboi board or the driver? I don't believe there is a correction, but I'll double check.
  • fuzion_reaktor
    No I don't think there is a correction. All I have done is wire the motors' wires to their respective pins.
  • D_Hersey
    The schematic I am looking at is here:
    http://www.reprap.org/mediawiki/images/4/41/Baboi_schematic.png
    If you look at the motor driver section in the lower right, you will see what I am talking about.
  • fuzion_reaktor
    Yes I can see that. From what I can tell, there is no correction. The motor connector is just a set of molex pins.
