element14's The Ben Heck Show
Forum Stepper Motor Troubleshooting
  • Replies 44 replies
  • Subscribers 33 subscribers
  • Views 7385 views
  • help
  • 3d
  • me
  • tags
  • stepper
  • stuff
  • help!
  • printing
  • motor
  • heck
  • ben
fuzion_reaktor
fuzion_reaktor over 12 years ago
Hello, my name is Peter R and for the past several months I have been building a 3D printer. I have the frame and everything done, but I consistently run into the issue where my stepper motors run erratically; when I issue a movement command they change direction at random, move in unpredictable spurts, clank, grind and make weird noises--and that's if I'm lucky enough to get them running at all. They appear to be uni-polar motors, and I have wired their four wires in as many orientations as possible and still get the same issue? Is this a board problem, or the motors themselves?
The motors are 17H249-02S motors, manufactured by Xuquan motor, but there is little documentation on them on the internet as far I have found.
Many thank to whoever can answer this.
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to D_Hersey +2
    Huzzah (yes I say huzzah) I have inadvertently solved my problem. My end-stops were wired improperly so the control board thought that they were closed. Thus my motors could never move in the direction…
  • fuzion_reaktor
    fuzion_reaktor over 12 years ago in reply to kidiccurus +1
    Motors, yes are a plugging in problem. This is just weird. But switching the two works and I have successfully printed a small misshaped cube...Progress...
  • D_Hersey
    0 D_Hersey over 12 years ago
  • fuzion_reaktor
    0 fuzion_reaktor over 12 years ago in reply to D_Hersey
    Huzzah (yes I say huzzah) I have inadvertently solved my problem. My end-stops were wired improperly so the control board thought that they were closed. Thus my motors could never move in the direction that would lead them to move past the end-stop. I feel like such an idiot right now. Also, I hot glued my molex metal crimp contacts into their sockets so they wouldn't get pushed out by the pins, which was causing my motors to run erratically.
  • fuzion_reaktor
    0 fuzion_reaktor over 12 years ago in reply to fuzion_reaktor
    And now the extruder just melted itself...such is my life.
  • kidiccurus
    0 kidiccurus over 12 years ago in reply to fuzion_reaktor
    Doh! Were you using a temperature sensor to ensure it didn't overheat. If not then I recommend you implement such a change immediately. Also, hot glue for the win!
  • fuzion_reaktor
    0 fuzion_reaktor over 12 years ago in reply to kidiccurus
    Actually yes, I was using a thermistor, however, even though a wrap of kapton tape, it somehow contacted the heater block and then I almost had a fire. Either that or it failed, I can't really tell as it melted and it stuck inside the block.
  • kidiccurus
    Perhaps you could cut open the block to troubleshoot? Also, consider a thermal cut-out fuse for an extra layer of safety.
  • fuzion_reaktor
    I don't have the equipment to saw through solid metal, as small a piece of metal as it is. Also, that's a good idea about a fuse, I once was considering installing one however my motor issues were the main issue and distracted me. What happened was I was just testing to see if they would home themselves properly before starting a print. A few seconds later there's smoke.
  • kidiccurus
    Well, I haven't a clue what caused this. I guess you just have to replace the damaged parts and add the fuse. Hopefully it won't happen again, but if it does, post it as a new discussion on the 3d printer section and see what other people say. Please bear in mind that I an by no means an expert at this.
  • fuzion_reaktor
    I think my thermistor connection contacted the heater block causing a false read.
  • fuzion_reaktor
    Wait, scratch that, yes it was contacting making a bad reading, but my printer is reading the heat-bed thermistor as the hot-end thermistor. this piece of junk, why can't it work properly!?
