element14's The Ben Heck Show
Forum dc generator
  • Replies 11 replies
  • Subscribers 32 subscribers
  • Views 1448 views
dc generator
majorkuso
majorkuso over 10 years ago
I want to use a dc motor to charge a cellphone, how would I choose an off the shelf dc motor to use as the generator? I am looking at something like this  https://www.amazon.com/2-5KG-Micro-Speed-Reducing-Motor/dp/B009AQLDSS/ref=pd_day0_469_2?ie=UTF8&psc=1&refRID=K49X1E2DXFR58MMTJ742. I am assuming if I can match the rpm it should be close to the running specs? I would like a similar current but higher voltage to step down to 5 volts, however I am think a buck/boost converter would be adequate?
  • william_hoffer
    william_hoffer over 10 years ago +1
    don't know if this will help but this how ben did it way back in 2011 Episode 10: See Ben Build a Hand Crank Phone Charger
    jw0752 over 10 years ago in reply to majorkuso +1
    Hi James, It is a matter of conservation of energy. You can not get more power out than is put into the system. In most cases like this one you will get a lot less out than is put in due to heat losses…
  • majorkuso
    I may have a 3 phase motor that i can use I will have to see how much it can put out, it came from a crank flashlight
