element14's The Ben Heck Show
Forum Convert mobile DVD player to Pi Entertainment system
  • Subscribers 30 subscribers
  • Views 705 views
  • questions_communityfeedback
threealarm
threealarm over 9 years ago
Ben,
I've got these portable dvd players that mount on the rear head rests in a vehicle.
I'm planning on removing the DVD guts, then replace with a R PIv3 with kodi installed.
Since this is to be designed with my kids in mind, I also plan to add in the necessary module for  wireless game controllers.
I was wondering if you would be interested in doing a build, I could send you one of the sets that I have.
  • william_hoffer
    william_hoffer over 9 years ago +1
    First off I like te idea. I do have two questions, First off by your last sentance I am taken to understand you are talking about a system that has twin screen (one for the back of the driver seat and…
  • william_hoffer
    First off I like te idea. I do have two questions, First off by your last sentance I am taken to understand you are talking about a system that has twin screen (one for the back of the driver seat and one for the back of the passanger seat) Am I correct? Second question, can you give me the brand and model number so I may do some research to see what I might be able to do with this set up?
  • d3angc
    d3angc over 9 years ago
    I have built one. It works quite well. I would suggest that you use an in car DVD player with aux input and solder direct to this channel. Then wire the power input from the pi to the built in usb on the dvd player. It will all run from the built in battery and you can port out the pi usb to the bottom of the player so wired controllers can still be used.
