Hack Like Heck
  • Hack Like Heck
Hack Like Heck
Blog David's HLH Build Part 3
Join Hack Like Heck to participate - click to join for free!
  • Author Author: a531016
  • Date Created: 27 Mar 2018 9:29 PM Date Created
  • Views 2166 views
  • Comments 6 comments
  • hlh
  • davids hlh blog
a531016
a531016
27 Mar 2018
I am going to keep this update brief as a bit of a tease!
The breadboard is now complete, so I can now focus on how all the working components are going to squeeze in and work together.
I have also spent some time in Autodesk Fusion 360 designing the 3D printed parts.
As I stated in my declaration, I wanted to learn and improve what I know, and I am certainly doing that. I don't want to give too much away, but all will be revealed in the video!
What do you think of the concept, I am trying to keep it small enough to be pocketable! Any advice? What would you like to see?
  • a531016
    a531016 over 8 years ago in reply to makerkaren +2
    I have thought about it, I promise! It's not particularly clear from the picture above, but the leading edge (top edge) of the screen case is slightly raised, with the main body if it not fully closing…
  • a531016
    a531016 over 8 years ago in reply to genebren +1
    Thank you! And a very good question! The quoted capacity of the boosted output is 2,500 mAh at 5V (the cell itself 3.7V at 9.62Wh). This should give me 12.5 Watt Hour. Although I can find plenty of data…
  • mayermakes
    mayermakes over 8 years ago in reply to a531016 +1
    you lucky guy...my Setup draws so much current I had to Switch to a 2cell Lipo to dirstribute the load. but I get about 2,5hours runtime. How are you approaching the Sound issue with the pi Zero (Gpio…
  • makerkaren
    makerkaren over 8 years ago
    Are you at all concerned about how/where the screen will impact the buttons when it is folded closed?
  • makerkaren
  • a531016
    It's not particularly clear from the picture above, but the leading edge (top edge) of the screen case is slightly raised, with the main body if it not fully closing flat onto the case. The hinge detail was also sized to hold the body up a touch, and also has a detent in the mechanism to hold it in the closed position.
