Hack Like Heck
  • Hack Like Heck
Hack Like Heck
Blog David's HLH Build Part 3
Join Hack Like Heck to participate - click to join for free!
  • Author Author: a531016
  • Date Created: 27 Mar 2018 9:29 PM Date Created
  • Views 2164 views
  • Comments 6 comments
  • hlh
  • davids hlh blog
a531016
a531016
27 Mar 2018
I am going to keep this update brief as a bit of a tease!
The breadboard is now complete, so I can now focus on how all the working components are going to squeeze in and work together.
I have also spent some time in Autodesk Fusion 360 designing the 3D printed parts.
As I stated in my declaration, I wanted to learn and improve what I know, and I am certainly doing that. I don't want to give too much away, but all will be revealed in the video!
What do you think of the concept, I am trying to keep it small enough to be pocketable! Any advice? What would you like to see?
  • a531016
    a531016 over 8 years ago in reply to makerkaren +2
    I have thought about it, I promise! It's not particularly clear from the picture above, but the leading edge (top edge) of the screen case is slightly raised, with the main body if it not fully closing…
  • a531016
    a531016 over 8 years ago in reply to genebren +1
    Thank you! And a very good question! The quoted capacity of the boosted output is 2,500 mAh at 5V (the cell itself 3.7V at 9.62Wh). This should give me 12.5 Watt Hour. Although I can find plenty of data…
  • mayermakes
    mayermakes over 8 years ago in reply to a531016 +1
    you lucky guy...my Setup draws so much current I had to Switch to a 2cell Lipo to dirstribute the load. but I get about 2,5hours runtime. How are you approaching the Sound issue with the pi Zero (Gpio…
    genebren over 8 years ago
    Looking good.  You seem to have gotten the component count (and sizes) down to a bare minimum.  Any idea on the runtime for a single Li-ion cell?
    Good luck and keep pushing.
    Gene
  • a531016
    Thank you!
    And a very good question! The quoted capacity of the boosted output is 2,500 mAh at 5V (the cell itself 3.7V at 9.62Wh). This should give me 12.5 Watt Hour. Although I can find plenty of data on the RPI 0 (180 mA) the screen seems to be a bit of a mystery. I guess the worst case is that it draws 1.1 A @ 5V or 5.5 Watts (the boost circuit is limited to 1.2A) so in theory, I should get just over 2 hours?
    The best way to know is to stick an ammeter in there while I am wiring up the power switch. Or just try it of course! Either way, thought the testing and debugging, I have probably run it for an hour already, and the cell has only dropped from 3.9V to 3.7V, so it looks promising!
  • mayermakes
    How are you approaching the Sound issue with the pi Zero (Gpio or snitching it off the hdmi? or got another idea?)
  • mayermakes
  • a531016
    a531016 over 8 years ago in reply to mayermakes
    I had originally planned on building a low pass filter and GPIO, however, I understand that needs GPIO 18 - which is used by the screen!
    I have an HDMI to VGA adapter with a 3.5mm jack standing by to sacrifice itself for the project!
