Hack Like Heck
  • Hack Like Heck
Hack Like Heck
Blog Mini Arcade Build Log #1 - Hack Like Heck - The Trouble with Joysticks
Join Hack Like Heck to participate - click to join for free!
  • Author Author: andywest
  • Date Created: 22 Mar 2018 4:34 PM Date Created
  • Views 1313 views
  • Comments 5 comments
andywest
andywest
22 Mar 2018
“When all you have is a 3D printer, everything looks like… filament… or something.”
Now that Act 1 of the Hack Like Heck competition is over, it’s time to get hacking! Since this is my first time doing a build like this, I wasn’t sure exactly where to begin. So I (somewhat arbitrarily) chose to start with the controls.
Before getting into the actual build, I spent quite a bit of time planning and procuring the parts I thought I would need. This includes a bag of cheap tactile switches and a USB joystick encoder. My thought process was something like:
switches + USB encoder + 3D-printed parts = mini arcade joystick
Seems sensible, right? Well, not exactly. I should have listened to the other, more experienced community members who realized that great controls are essential from the start. That is to say, a functional joystick isn’t necessarily a good joystick.
I started by downloading and printing some free models. They did technically work, but the plastic-on-plastic feel was weird and kind of squeaky. I added some silicone lubricant but it didn’t help. I tried various modifications and even made some of my own designs from scratch, but I wasn’t really satisfied with any of them. Also, the switches were a bit too noisy and had too much resistance.
A graveyard of failed joystick attempts
So I took a step back and thought about my favorite gamepads and what I like about them. I came up with a set of criteria for the joystick:
  1. It has to be reasonably priced. Sure, I can tear apart a PS4 or Xbox One controller, but do I really want to spend $40 for $5 worth of parts?
  2. It has to have a stick that I can easily convert to a classic arcade-style joystick.
  3. It has to be comfortable.
  4. Due to time and budget constraints, it has to work with USB directly, or the USB encoder I’ve already purchased.
In the end, this is what I decided to use:
No official GameCube controllers were harmed in the making of this build.
This third-party wireless GameCube controller has a decent feel, but the signal cuts out intermittently which makes it pretty much worthless. I was happy to sacrifice it for this project. There are two analog sticks. Unfortunately, this controller is not USB-compatible, and my USB encoder only accepts digital inputs. Is there a way to convert the sticks from analog to digital without extra hardware? It turns out there is!
It’s working! It’s working! The modded GameCube stick
If you want to see exactly how I did it, watch for my project video to be released on April 4.
Note: Don’t worry if you don’t have a GameCube controller to spare. The final project uses a similar analog stick that I found on Amazon and will include in the parts list for the build.
After wasting a lot of time going down the wrong path with tact switches, it’s great to have found a better alternative. I know that having solid controls will make this device much more enjoyable to play.
  • andywest
    andywest over 8 years ago in reply to rocits +2
    Have you ever seen a geodesic sphere rubberized effect No, I've never seen that. It does sound cool, but I've already spent too much time on the controls. I'm into 3D printing the case at the moment. I…
    genebren over 8 years ago +1
    Nice little controller. Some of the early joysticks looked like they may have worked, but the feel is everything. Good luck on the rest of your build. Gene
  • rocits
    rocits over 8 years ago +1
    The 'graveyard' lol that is impressive on it's own Andy! The joystick looks fantastic ! Have you ever seen a geodesic sphere rubberized effect !?..maybe something like getting a push-bike tire and cutting…
    Gene
    Gene
  • andywest
    andywest over 8 years ago in reply to genebren
    Thanks! It's true, I had a lot of hope for some of those, but I wanted something really smooth and they just weren't cutting it.
