element14's The Ben Heck Show
Documents Help Ben Heck Finish His Portable N64!
  • Date Created: 6 Apr 2017 5:26 PM Date Created
  • Last Updated Last Updated: 28 Sep 2017 9:05 PM
  • Views 5187 views
  • Comments 55 comments
Connect with TBHS
Featured Bonus Content
See All Episodes
You must be logged into the element14 Community to submit Feedback for Ben!
Ben Heck gives an update on the much anticipated Portable N64 and requests help from the community with completing the build.  A portable N64 is one of the most frequently requested builds from members but is difficult to hack because it’s easy to damage and requires a lot of rewiring to make it portable.  Specifically, Ben needs help getting the RAM expansion to work. Help Ben finish his N64 Portable in the comments below!
View Progress Made on the Portable N64 in Previous Episodes:
Episode 275: Ben Heck's Portable N64 Part 1 Episode
Episode 276: Ben Heck's Portable N64 Part 2 Episode
In the Comments Below Submit Your Feedback to Help Ben Heck Complete His N64 Portable!
  • portable n64
  • n64 portable
  • n64
  • nintendo 64
  • tbhs_n64
  • jon4248
    jon4248 over 9 years ago +10
    Am I the only one that found this via google? Reverse engineering the jumper pak. | The Official ModRetro Forums Edit - info about: ram swap | The Official ModRetro Forums edit: or perhaps this if your…
  • sudos
    sudos over 9 years ago +6
    Shielded ribbon cable would probably be the first thing to get your hands on to try. 3M stuff, of course, nothing else. this was a problem with the PCIe stuff when bitcoin and dogecoin miners were huge…
  • mayermakes
    mayermakes over 9 years ago +5
    I think the problem is actually in the timing for the ram, (15cm/ns in copper wire if I remember correctly) Because of the way the board is routed I think the traces are calculated to have the suitable…
  • dwarg91
    dwarg91 over 9 years ago
    make sure that the traces for the rambus do not go anywhere else as that might be where some of the instability is coming from. Also make sure that the in used traces aren't connected as they might be introducing reflections in the signal.
  • dwarg91
