Project Videos
  • Project Videos
Project Videos
Documents Guitar Vacuum Tube Distortion Pedal -- Episode 518
  • Date Created: 28 Sep 2021 5:34 PM Date Created
  • Last Updated Last Updated: 1 Oct 2021 7:24 AM
  • Views 6011 views
  • Comments 13 comments
Clem found his way into Electronics through modding guitars. An since he has some vintage Tubes in stock, he decided to make a project that takes him back to his roots bloody roots. A 3 stage Tube-based Distortion Pedal for that authentic warm fuzzy rock'n'roll sound, but it turns out this DIY stompbox can also put out a pretty brutal sound when paired with a modern Amplifier.
Supplemental Content:
  • Episode 518: Bonus Content: Foot Pedal Mod
Bill of Material:
Product Name Manufacturer Quantity Buy Now
Rotary Potentiometer, 10 kohm, 1 Turns, Linear, 200 mW, ± 20%, P160 Series TT ELECTRONICS / BI TECHNOLOGIES 6 Buy Now
Phone Audio Connector, 3 Contacts, Jack, 6.35 mm, Panel Mount, Nickel Plated Contacts, Metal Body Switchcraft 4 Buy Now
Additional Parts:
Product Name
Compatible Tubes: ECC83, ECC82, ECC81, 12AU7, 12AX7
schematic.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • vacuum tube
  • guitar pedal
  • clem
  • guitar
  • e14presents_mayermakes
  • switchcraft
  • tt electronics
  • friday_release
  • mayermakes
  • e14p_CMM
  • phoenixcomm
    phoenixcomm over 5 years ago
    mayermakes I like your stuff but hate your soldering techniques. From what I have seen in your vids you apply solder to the part without a mechanical connection. Also, with solder, less is more, if it is stranded wire, you should see the strands through the solder.
    Soldering is like a dance. To wire to a post or turret, I pre-tin my wires in a solder pot. So now when I heat the turret the solder on the wire will melt. this method requires almost no extra solder.
    For radial components, place the component bend the leads 90deg to the PCB. Insert and bend the leads outward to secure the component. then while heating the wire which will transfer heat to the land. apply solder to the land which in turn will secure the wire to the land. lastly, trim wire.
    For more info please visit my blogs called soldering school.
    ~~Cris
  • phoenixcomm
    ~~Cris
  • mayermakes
    mayermakes over 5 years ago in reply to phoenixcomm
    Can you point me to the specific shots you are refering to?
    I think I don't really get what improper techniques you exactly mean. I use a lto of different methods depending on material components and number of hands I have available during filming.
