Project Videos
  • Project Videos
Project Videos
Documents Guitar Vacuum Tube Distortion Pedal -- Episode 518
  • Date Created: 28 Sep 2021 5:34 PM Date Created
  • Last Updated Last Updated: 1 Oct 2021 7:24 AM
  • Views 6011 views
  • Comments 13 comments
Clem found his way into Electronics through modding guitars. An since he has some vintage Tubes in stock, he decided to make a project that takes him back to his roots bloody roots. A 3 stage Tube-based Distortion Pedal for that authentic warm fuzzy rock'n'roll sound, but it turns out this DIY stompbox can also put out a pretty brutal sound when paired with a modern Amplifier.
Supplemental Content:
  • Episode 518: Bonus Content: Foot Pedal Mod
Bill of Material:
Product Name Manufacturer Quantity Buy Now
Rotary Potentiometer, 10 kohm, 1 Turns, Linear, 200 mW, ± 20%, P160 Series TT ELECTRONICS / BI TECHNOLOGIES 6 Buy Now
Phone Audio Connector, 3 Contacts, Jack, 6.35 mm, Panel Mount, Nickel Plated Contacts, Metal Body Switchcraft 4 Buy Now
Additional Parts:
Product Name
Compatible Tubes: ECC83, ECC82, ECC81, 12AU7, 12AX7
schematic.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • vacuum tube
  • guitar pedal
  • clem
  • guitar
  • e14presents_mayermakes
  • switchcraft
  • tt electronics
  • friday_release
  • mayermakes
  • e14p_CMM
  • mayermakes
    mayermakes over 5 years ago in reply to kmikemoo
    A project like this is a good entry into using tubes as it is a low voltage low cost application.
    I figured it would not make much sense if people could not hear the difference, so I opted to prime  the video with a little demo.
  • phoenixcomm
    phoenixcomm over 5 years ago
    mayermakes I like your stuff but hate your soldering techniques. From what I have seen in your vids you apply solder to the part without a mechanical connection. Also, with solder, less is more, if it is stranded wire, you should see the strands through the solder.
    Soldering is like a dance. To wire to a post or turret, I pre-tin my wires in a solder pot. So now when I heat the turret the solder on the wire will melt. this method requires almost no extra solder.
    For radial components, place the component bend the leads 90deg to the PCB. Insert and bend the leads outward to secure the component. then while heating the wire which will transfer heat to the land. apply solder to the land which in turn will secure the wire to the land. lastly, trim wire.
    For more info please visit my blogs called soldering school.
    ~~Cris
  • kmikemoo
    kmikemoo over 5 years ago
    mayermakes  Very cool.  I really like the tube stuff.  I haven't built anything with tubes but it intrigues me and I think about it when I see builds like this.  Maybe someday. image
    Back in the day, I thought Marshall amps were the way to go because they were tube style.  The overdrive was awesome.
    Thanks for showing what the system sounded like bypassing the pedal.  I was wondering about that when it came up in the video.  <thumbs up emoji>
