Project Videos
  • Project Videos
Project Videos
Documents Make your Own Auto-Sensing Solder Fume Extractor -- Episode 523
  • Date Created: 1 Nov 2021 10:51 PM Date Created
  • Last Updated Last Updated: 5 Nov 2021 8:24 AM
  • Views 6073 views
  • Comments 9 comments
Forget to turn on the extractor whilst soldering, me too. So I’ve made an automatic sensing extractor, that uses a particulate sensor to monitor the air quality and automatically change the fan speed to match the air quality, therefore creating the optimum extraction for the current job.
Supplemental Content:
  • Episode 523: Bonus Content: Extractor
  • Link to the Github:  https://github.com/hifromkatie/SolderingExtractor
Bill of Material:
Product Name Manufacturer Quantity Buy KitBuy Kit
RASPBERRY PI PICO RASPBERRY-PI 1 Buy Now
HONEYWELL Gas Detection Sensor, PM2.5, Laser Scattering, Air, 15 %, HPM Series HONEYWELL 1 Buy Now
MOLEX Cable Assembly, 8Pos, PicoBlade Receptacle to PicoBlade Receptacle, 8 Ways, 1.25 mm, 1 Row, 300 mm MOLEX 1 Buy Now
EBM-PAPST DC Axial Fan, 12 V, Square, 119 mm, 32 mm, Ball Bearing, 129 CFM EBM-PAPST 1 Buy Now
Slide Potentiometer, Slide, Low Profile, 10 kohm, ± 20%, 500 mW, Linear, Through Hole BOURNS 1 Buy Now
DURATOOL Filter, Carbon, Replacement, for use with D00374/D00375 Soldering Fume Absorbers DURATOOL 1 Buy Now
ONSEMI Buck (Step Down) Switching Regulator, Fixed, 7V-40Vin, 5V/3A out, 63 kHz, TO-220-5 ONSEMI 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 100 µF, 25 V, MCGPR Series, ± 20%, Radial Leaded, 2000 hours @ 85°C MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 1000 µF, 25 V, MCGPR Series, ± 20%, Radial Leaded, 2000 hours @ 85°C MULTICOMP PRO 1 Buy Now
PULSE ELECTRONICS Toroidal Inductor, Vertical, KlipMount Series, 100 µH, 3.6 A, 0.045 ohm, ± 20% PULSE ELECTRONICS 1 Buy Now
MULTICOMP PRO Schottky Rectifier, 40 V, 3 A, Single, DO-201AD, 2 Pins, 950 mV MULTICOMP PRO 1 Buy Now
PRO SIGNAL DC Power Connector, Receptacle, 500 mA, 2.1 mm, Chassis Mount, Solder PRO SIGNAL 1 Buy Now
PRO ELEC AC/DC Power Supply, ITE, 1 Output, 12 W, 12 V, 1 A PRO ELEC 1 Buy Now
2.85mm Silver Cosmic PLA Filament FILAMENTIVE 1 Buy Now
MULTICOMP PRO 3D Printer Filament, 2.85mm Dia, Black, PLA, 1 kg MULTICOMP PRO 1 Buy Now
TR FASTENINGS Insert, Blind, Heat-SertTm, Brass, Unheaded, 5.8mm x 4.4mm, M3, Pack of 100 TR FASTENINGS 4 Buy Now
TR FASTENINGS Machine Screw, DIN 965, M3, 25 mm, Steel, Bright Zinc, Flat / Countersunk Head Pozidriv TR FASTENINGS 4 Buy Now
element14 presents
element14 presents  |  About Katie |  Project Videos
  • e14p_KD
  • rpi pico
  • pm2.5 sensor
  • e14presents_kdumont
  • pwm
  • fume extractor
  • pico
  • e14presents_katiedumont
  • raspberry pi
  • katie
  • soldering
  • extractor
  • solder fumes
  • friday_release
    beacon_dave over 4 years ago
    Another nice project.
    Would it be worth considering the option to connect a second remote sensor ?
    If you work with a desktop lamp, then perhaps a remote sensor could be positioned more overhead on the lamp to be able to detect the smoke faster as it rises vertically from the soldering iron tip. Once the fan starts up though, the smoke will be drawn horizontally and away from the overhead sensor so you would still need the second sensor to keep the fan running.
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to beacon_dave
    beacon_dave great idea. I have a commercial extractor.  I think for me is to use a current sensor on the power line to my Metcal soldering system to turn on the extractor.
    ~~Cris
  • hifromkatie
    hifromkatie over 4 years ago in reply to phoenixcomm
    That's a good idea about using the current sensor on the power supply to turn it on, I hadn't thought of a solution like that
  • hifromkatie
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to hifromkatie
    hifromkatie and if you do it right you don't even need a CPU!
