Project Videos
  • Project Videos
Project Videos
Documents Make your Own Auto-Sensing Solder Fume Extractor -- Episode 523
  • Date Created: 1 Nov 2021 10:51 PM Date Created
  • Last Updated Last Updated: 5 Nov 2021 8:24 AM
  • Views 6073 views
  • Comments 9 comments
Forget to turn on the extractor whilst soldering, me too. So I’ve made an automatic sensing extractor, that uses a particulate sensor to monitor the air quality and automatically change the fan speed to match the air quality, therefore creating the optimum extraction for the current job.
Supplemental Content:
  • Episode 523: Bonus Content: Extractor
  • Link to the Github:  https://github.com/hifromkatie/SolderingExtractor
Bill of Material:
Product Name Manufacturer Quantity Buy KitBuy Kit
RASPBERRY PI PICO RASPBERRY-PI 1 Buy Now
HONEYWELL Gas Detection Sensor, PM2.5, Laser Scattering, Air, 15 %, HPM Series HONEYWELL 1 Buy Now
MOLEX Cable Assembly, 8Pos, PicoBlade Receptacle to PicoBlade Receptacle, 8 Ways, 1.25 mm, 1 Row, 300 mm MOLEX 1 Buy Now
EBM-PAPST DC Axial Fan, 12 V, Square, 119 mm, 32 mm, Ball Bearing, 129 CFM EBM-PAPST 1 Buy Now
Slide Potentiometer, Slide, Low Profile, 10 kohm, ± 20%, 500 mW, Linear, Through Hole BOURNS 1 Buy Now
DURATOOL Filter, Carbon, Replacement, for use with D00374/D00375 Soldering Fume Absorbers DURATOOL 1 Buy Now
ONSEMI Buck (Step Down) Switching Regulator, Fixed, 7V-40Vin, 5V/3A out, 63 kHz, TO-220-5 ONSEMI 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 100 µF, 25 V, MCGPR Series, ± 20%, Radial Leaded, 2000 hours @ 85°C MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 1000 µF, 25 V, MCGPR Series, ± 20%, Radial Leaded, 2000 hours @ 85°C MULTICOMP PRO 1 Buy Now
PULSE ELECTRONICS Toroidal Inductor, Vertical, KlipMount Series, 100 µH, 3.6 A, 0.045 ohm, ± 20% PULSE ELECTRONICS 1 Buy Now
MULTICOMP PRO Schottky Rectifier, 40 V, 3 A, Single, DO-201AD, 2 Pins, 950 mV MULTICOMP PRO 1 Buy Now
PRO SIGNAL DC Power Connector, Receptacle, 500 mA, 2.1 mm, Chassis Mount, Solder PRO SIGNAL 1 Buy Now
PRO ELEC AC/DC Power Supply, ITE, 1 Output, 12 W, 12 V, 1 A PRO ELEC 1 Buy Now
2.85mm Silver Cosmic PLA Filament FILAMENTIVE 1 Buy Now
MULTICOMP PRO 3D Printer Filament, 2.85mm Dia, Black, PLA, 1 kg MULTICOMP PRO 1 Buy Now
TR FASTENINGS Insert, Blind, Heat-SertTm, Brass, Unheaded, 5.8mm x 4.4mm, M3, Pack of 100 TR FASTENINGS 4 Buy Now
TR FASTENINGS Machine Screw, DIN 965, M3, 25 mm, Steel, Bright Zinc, Flat / Countersunk Head Pozidriv TR FASTENINGS 4 Buy Now
element14 presents
element14 presents  |  About Katie |  Project Videos
  • e14p_KD
  • rpi pico
  • pm2.5 sensor
  • e14presents_kdumont
  • pwm
  • fume extractor
  • pico
  • e14presents_katiedumont
  • raspberry pi
  • katie
  • soldering
  • extractor
  • solder fumes
  • friday_release
  • kmikemoo
    kmikemoo over 4 years ago
    Nice job, hifromkatie.  I like your plan to keep the fan running all the time.  This way the sensor has the most opportunity to detect the fumes.  Great project.
  • kmikemoo
  • hifromkatie
    hifromkatie over 4 years ago in reply to kmikemoo
    Thanks, yes, having it slow creates just enough "pull" that the fumes are directed towards the sensor. I have discovered that it detects better if I put it upside down too, as it draws it in towards the top!
