Project Videos
  • Project Videos
Project Videos
Documents Game Guy - The Unportable Game Boy -- Episode 531
  • Author Author: kellyhensen
  • Date Created: 22 Dec 2021 6:10 PM Date Created
  • Last Updated Last Updated: 31 Dec 2021 8:24 AM
  • Views 146372 views
  • Likes 11 likes
  • Comments 45 comments
Due to the need for both speed and precise timing, video conversion tasks are often left to FPGAs or similar devices. But in this episode, Andy demonstrates how a $4 microcontroller can be used to convert Game Boy video into something that can be displayed on a big screen. Combine that with an NES controller port, and you've got a TV console that can play original Game Boy games!
Supplemental Content:
  • Link to Github Files:  https://github.com/andy-west/consolized-game-boy
Bill of Material:
Raspberry Pi Pico, Microcontroller Board, RP2040, 32 bit, 2MB Flash, ARM Cortex-M0+ RASPBERRY-PI 1 Buy Now
Resistor Kit, 10Ohm To 1MOhm, 610 Pieces, 250mW, Carbon Film, 10 Pieces Per Value, E12 Series Velleman SA 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP Texas Instruments 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP New TEXAS INSTRUMENTS 4 Buy Now
Additional Parts Manufacturer Quantity
1 x 50 Pins IDC 2.54mm Card Edge Connector for 1.27mm Flat Ribbon Cable
1 x 50 Pin IDC 2.54mm Pitch F/F Connector 1.27mm Flat Ribbon Cable
element14 presents
element14 presents  |  About Andy |  Project Videos
  • project_video
  • game_boy
  • element14presents_andywest
  • element14presents
  • friday_release
  • k3naya
    k3naya over 2 years ago
    Hi, I'm working with your development and it looks good. I've installed your most recent firmware(gb_consolizer_model_b_v2_4_2, but I can't get a Nintendo controller to work properly. Only the A button works, and it's mixed up with the Start button. I've checked everything, but I can't find the problem. Do you know what could be happening? Thanks, regards.
  • Joe_O
    Joe_O over 2 years ago in reply to k3naya
    Is it an original NES controller or aftermarket?  They both should work, but aftermarket seem to have varying timing, even different shift register idle logic level.  Switching to an I2C controller like Wii or NES Classic is more reliable, but the old school should work still too .  I tested original and a aftermarket with the latest 2.4.2
  • k3naya
    k3naya over 2 years ago in reply to Joe_O
    Use original controller, data gpio11, latch gp12, clock gp14. correct? and follow this schematic
    *Seeing your name I assume you did it :)
  • Joe_O
    The PCB pads and code are set for pins 8,9,10 and if you change the code you have to uncomment a #define so that it will use the NES controller (set for an I2C controller by default).
    Are you trying to use the other pins for any special reason?
  • Joe_O
  • k3naya
    sorry i said gpio 11, rather than pin11, its the same gpio 11 and pin8.... , i will check another controller and review the welds, regards
  • Joe_O
    hehe, we both said it wrong.  I should have said GP8, GP9, GP10
