Project Videos
  • Project Videos
Project Videos
Documents Game Guy - The Unportable Game Boy -- Episode 531
  • Author Author: kellyhensen
  • Date Created: 22 Dec 2021 6:10 PM Date Created
  • Last Updated Last Updated: 31 Dec 2021 8:24 AM
  • Views 145967 views
  • Likes 11 likes
  • Comments 45 comments
Due to the need for both speed and precise timing, video conversion tasks are often left to FPGAs or similar devices. But in this episode, Andy demonstrates how a $4 microcontroller can be used to convert Game Boy video into something that can be displayed on a big screen. Combine that with an NES controller port, and you've got a TV console that can play original Game Boy games!
Supplemental Content:
  • Link to Github Files:  https://github.com/andy-west/consolized-game-boy
Bill of Material:
Raspberry Pi Pico, Microcontroller Board, RP2040, 32 bit, 2MB Flash, ARM Cortex-M0+ RASPBERRY-PI 1 Buy Now
Resistor Kit, 10Ohm To 1MOhm, 610 Pieces, 250mW, Carbon Film, 10 Pieces Per Value, E12 Series Velleman SA 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP Texas Instruments 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP New TEXAS INSTRUMENTS 4 Buy Now
Additional Parts Manufacturer Quantity
1 x 50 Pins IDC 2.54mm Card Edge Connector for 1.27mm Flat Ribbon Cable
1 x 50 Pin IDC 2.54mm Pitch F/F Connector 1.27mm Flat Ribbon Cable
element14 presents
element14 presents  |  About Andy |  Project Videos
  • project_video
  • game_boy
  • element14presents_andywest
  • element14presents
  • friday_release
  • p0z1tr0n
    p0z1tr0n over 4 years ago
    Nice work, thanks for sharing.
    I'm just wondering if you would mind explaining why you included the nops? I found that if I remove them I was able to get a stable video signal with the pico clocked at just 150MHz.
  • andywest
    andywest over 4 years ago in reply to p0z1tr0n
    Are you saying that you built this project and you're able to play games with the Pico at that frequency? If so, what games did you try? I found that the video timings vary between different titles based on things like sprite usage. For example, Tetris might look fine, while F1 Race has weird artifacts. It took a long time to get the image correct across all my games.
  • andywest
  • p0z1tr0n
    p0z1tr0n over 4 years ago in reply to andywest
    I tried about a dozen games including the Super Mario Land games, Tetris, Pokemon, Zelda, Final Fantasy, Nigel Mansell and a few others as well. Everything I tried so far has worked at 150MHz.
    That was until I tried F1 Race and it has some significant artifacts, so I tried your code again unmodified and it has the same artifacts.
    The reason I started messing around with the timing originally was because my Wario Land cartridge and was getting artifacts with your original code. I found that if I removed a couple of the NOPs it fixed the problem with Wario Land. I then tried removing all the NOPs and it didn't seem to make any difference, all the games I tried seemed to work fine.
    Next I started to reduce the clock down in 50MHz steps until it started to artifact. 150MHz was the lowest I could go and get stable video (at least with the games I've tried).
    Did you find any other games that had issues?
  • andywest
    I'm pretty sure I had trouble with Game & Watch Gallery.
    It's definitely better to run at the lower clock speed if you can. Without a PCB to add consistency, the timings are probably affected by a number of factors including wire length. It may need to be adjusted for each individual build.
