Project Videos
  • Project Videos
Project Videos
Documents Game Guy - The Unportable Game Boy -- Episode 531
  • Author Author: kellyhensen
  • Date Created: 22 Dec 2021 6:10 PM Date Created
  • Last Updated Last Updated: 31 Dec 2021 8:24 AM
  • Views 145934 views
  • Likes 11 likes
  • Comments 45 comments
Due to the need for both speed and precise timing, video conversion tasks are often left to FPGAs or similar devices. But in this episode, Andy demonstrates how a $4 microcontroller can be used to convert Game Boy video into something that can be displayed on a big screen. Combine that with an NES controller port, and you've got a TV console that can play original Game Boy games!
Supplemental Content:
  • Link to Github Files:  https://github.com/andy-west/consolized-game-boy
Bill of Material:
Raspberry Pi Pico, Microcontroller Board, RP2040, 32 bit, 2MB Flash, ARM Cortex-M0+ RASPBERRY-PI 1 Buy Now
Resistor Kit, 10Ohm To 1MOhm, 610 Pieces, 250mW, Carbon Film, 10 Pieces Per Value, E12 Series Velleman SA 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP Texas Instruments 1 Buy Now
LOGIC, BUS TRANSCVR OCTAL, 20DIP New TEXAS INSTRUMENTS 4 Buy Now
Additional Parts Manufacturer Quantity
1 x 50 Pins IDC 2.54mm Card Edge Connector for 1.27mm Flat Ribbon Cable
1 x 50 Pin IDC 2.54mm Pitch F/F Connector 1.27mm Flat Ribbon Cable
element14 presents
element14 presents  |  About Andy |  Project Videos
  • project_video
  • game_boy
  • element14presents_andywest
  • element14presents
  • friday_release
  • Joe_O
    Joe_O over 4 years ago
    If anyone's interested, I've got a single Pico version here:
    https://github.com/joeostrander/consolized-game-boy
    Having lots of fun with this.. thanks Andy!
  • andywest
    andywest over 4 years ago in reply to Joe_O
    Oh, man, that is seriously cool! I'll definitely be watching for the PCB. I'd love to make one of those once you've got it working.
  • Joe_O
    Joe_O over 4 years ago in reply to andywest
    gb vga pcba
    It works!
    I have 9 more bare PCBs -- If there's any interest, I could put them up on ebay (cheap).
    dougw over 4 years ago in reply to Joe_O
    Awesome work.
  • andywest
    What? That's amazing! Of course I'm interested. I don't need nine, but I'll take two off your hands. Please feel free to send me a dm and we can work out the details.
  • mattbraddock
    mattbraddock over 4 years ago in reply to Joe_O
    I am interested in this. Would love to take one.
  • Dominikus
    Dominikus over 3 years ago in reply to Joe_O
    Thanks for your work, i ordered your design by a PCB manufacture -- Works nearly flawless, only pressing all buttons at one time craches the GameBoy (for Tetris quick resetimage )
  • Joe_O
    Joe_O over 3 years ago in reply to Dominikus
    Is it an original NES controller?  I've noticed some differences between the aftermarket ones and the original that made the response a bit unpredictable. I think the aftermarket ones I saw kept the data line high when inactive and the original NES controllers kept it low when inactive.
    With the active-high, it's probably more important to level shift the signal down for the Pico.  I forgot to do that on that PCB rev.  You could try cutting the NES Data trace and instead of going directly to the Pico, try passing it through the remaining level shifter slot.  You'd have to bend the pin (11) out of the holder though, so that it is no longer grounded.
    bodge
    It's been a while since I looked at that rev of the board.  I'll update that version with this change.
  • Joe_O
    Also... Tetris has an auto-reset?  Wow, I never knew!
    If you press all buttons, try hitting Select as the last button. It might be my OSD* code causing the problem
    *For OSD, hold Select, then just tap Start
  • Dominikus
    Thanks for your answer.
    Yes it is an original gamepad (my socket looks different because i used a 4players adapter for parts).
    Without hardwaremodification it still crashes even if i press select as the last one.
    But now I have tasted blood and go for the V3 SMD version -- CPU and RAM has been transplanted. Now I am waiting for SMD resistors and crystals (because I use Super GameBoy for the parts)
    The v3 board has no link cable socket, right?
  • Dominikus
  • Joe_O
    Correct, there is no link cable socket, although it wouldn't be much work to add to the PCB design.
    I think you'll like V3, I also recommend picking up a cheap ($5-6) MyArcade wireless controller -- it performs awesome for me.  Stay tuned to the element14 youtube channel -- I can't give too much information away right now, but there might be some updates very soon.
  • Joe_O
    Hey Dominikus, I took a peek at the Tetris in-game reset and I was able to reproduce the issue.  I modified the code so that if it sees A+B+Select+Start, to send the button values, but immediately change the variable state for the buttons in the code so that they are no longer pressed. This seems to have done the trick as the reset works properly, even retaining the high-score list.
    github.com/.../gb_vga
