Project Videos
  • Project Videos
Project Videos
Documents Jumbo DIY LED -- Episode 533
  • Author Author: kellyhensen
  • Date Created: 12 Jan 2022 2:36 PM Date Created
  • Last Updated Last Updated: 14 Jan 2022 8:24 AM
  • Views 131083 views
  • Comments 7 comments
element14 presents
element14 presents  |  Andy's Profile   |  Project Videos
Inspired by an old Project14 Contest, Andy decides to make a jumbo-sized version of the WS2812B RGB LED. Not happy with the 10x and 20x prototypes he made, he decides to go bigger and make a 100x scale model of the LED. The project uses a WS2811 chip to control 3 power MOSFETs via a MOSFET driver chip. As the voltages and currents are higher than usual, calculations are needed to select the right heatsinks for the application.
Supplemental Content:
  • element14's Project14 - The Question of Scale
  • Andy's Project14 project
  • Jumbo RGB LED Code (github)
Bill of Material:
Arduino Uno Arduino 1 Buy Now
VOD3120AD Optically coupled MOSFET Driver VISHAY 3 Buy Now
Power MOSFET, N Channel, 30 V, 150 A, 0.0038 ohm, TO-220AB, Through Hole INFINEON 3 Buy Now
SK 400 37.5 SA Heat Sink, Square, PCB, Extruded, LED, 7.8 °C/W, 33 mm, 10 mm, 37.5 mm FISCHER ELEKTRONIK 3 Buy Now
Through Hole Resistor, 100 ohm, 2 W TT ELECTRONICS / WELWYN 3 Buy Now
Through Hole Resistor, 6.8 ohm, 5 W MULTICOMP PRO 3 Buy Now
1N4006G Standard Recovery Diode, 800 V, 1 A, Single, 1 V, 30 A TAIWAN SEMICONDUCTOR 1 Buy Now
Heat Sink Compound, Highly Conductive, Silicone, Tube, 25g SERVISOL – AAVID / BOYD 1 Buy Now
Screw Terminal 2 way WURTH ELEKTRONIK 1 Buy Now
Screw Terminal 3 way WURTH ELEKTRONIK 4 Buy Now
Additional Content:
Worldsemi WS2811
10W RED LED
10W GREEN LED
10W BLUE LED
Multistrand cable
MDF 6mm 500mm x 500xx (9)
2 x 4 lumber offcut (4)
Paint
  • driver
  • workshopshed
  • mosfet
  • heatsink
  • neopixels
  • led
  • ws2811
  • rgb
  • ws2812b
  • friday_release
    DAB over 4 years ago
    Great job Andy.
    I liked your PCB solder jib, very cool.
    Great job Andy.
  • Workshopshed
    Workshopshed over 4 years ago in reply to DAB
    That's a panavise Jr, it has come in very handy over the years.
    community.element14.com/.../panavise-jr
