Project Videos
  • Project Videos
Project Videos
Documents Open Source Inventory Warehousing System -- Episode 534
  • Author Author: kellyhensen
  • Date Created: 18 Jan 2022 5:04 PM Date Created
  • Last Updated Last Updated: 21 Jan 2022 8:24 AM
  • Views 15164 views
  • Likes 10 likes
  • Comments 8 comments
MAYER MAKES Engineering Resin (https://mayermakes.at/engineering-resin/)3D basics Color Ampule Black
For a lot of makers, selling their creations is a big goal.
Unsatisfied with the current options to sell DIY products Clem started building his own website. When many orders trickle in, it's easy to confuse items when packing. So Clem uses the REST API of his website a Raspberry pi 3A+ and a Barcode Scanner to build a warehousing system that helps you pack Orders and ship them out ASAP!
Supplemental Content:
  • Bonus Content - deep dive into the code with Clem
  • CAD Files and Code
Bill of Material:
Product Name Manufacturer Quantity
"MULTICOMP PRO Industrial Pushbutton Switch Multicomp pro 1 Buy Now
"PRO SIGNAL HDMI to VGA Adaptor Lead" Pro signal 1 Buy Now
"OPTICON Black USB Barcode CCD Scanner" Opticon 1 Buy Now
Raspberry PI 3A+  1 No longer stocked - see alternative below
Alternative:
"DFROBOT Single Board Computer Lattepanda Dfrobot 1 Buy Now
"ALCOSWITCH - TE CONNECTIVITY Industrial Pushbutton Switch Alcoswitch 1 Buy Now
Additional Parts:
Old PC monitor
Vga cable
PMMA for lasercutting or other material for mounting the SBC
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • clem
  • raspberry pi
  • rest api
  • scan
  • friday_release
  • mayermakes
  • kmikemoo
    kmikemoo over 4 years ago +2
    mayermakes Very cool. I have wondered from time to time how difficult it would be to integrate bar code scanning into inventory tracking. This episode was very helpful.
  • mayermakes
    mayermakes over 4 years ago in reply to phoenixcomm +2
    So where do I start: the preface this project is only showcasing 1 simple API call and making use of the Json response. Its only getting the orders that are ready for shipping and helps packing these…
  • mayermakes
    mayermakes over 4 years ago +1
    What APIs do you use for projects? any secrets you want to share? Mine is POSTMAN saves a lot of headaches when trying to figure out API communication!
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    thanks DAB
  • mayermakes
    mayermakes over 4 years ago in reply to kmikemoo
    glad it was of help!
  • mayermakes
    the Issue with the input() function in a python script mentioned in the video has been solved thanks to our viewer Rene Snijders from the netherlands!
    Here is his solution:
    Rene just wrote a simple input & print :
    ---- myprogramm.py
    #simple input
    barcode = input ("Enter Barcode :")
    print(barcode)
    ---- myprogramm.py
    Then in the terminal as root or sudo -i
    mkdir -p /etc/systemd/system/getty@tty1.service.d
    echo "[Service]" > /etc/systemd/system/getty@tty1.service.d/override.conf
    echo "ExecStart=" >> /etc/systemd/system/getty@tty1.service.d/override.conf
    echo "ExecStart=-/usr/bin/python3 /home/pi/myprogramm.py" >> /etc/systemd/system/getty@tty1.service.d/override.conf
    echo "StandardInput=tty"  >> /etc/systemd/system/getty@tty1.service.d/override.conf
    echo "StandardOutput=tty"  >> /etc/systemd/system/getty@tty1.service.d/override.conf
    sync
    sudo reboot
    And with every keyboard attached the program runs perfect.
    the most common barcode scanners mimic a HID (KeyBoard)
    Tested with a clean install of armbian ( on a OrangePi ) but systemd = systemd this must work for you to.
    I hope you got a spare Pi to test this
    Kind Regards from the Netherlands,
    René
    I had to adapt it a little bit for my application since Raspbian buster gave me a permission error even elevated as sudo:
    the Echo method did only give me permission errors so I edited the file in nano.
    changes I had to do on Raspbian Buster:
    sudo nano /etc/systemd/system/getty@tty1.service.d/override.conf
    enter these lines:
    StandardInput=tty1
    StandardOutput=tty1
    sync
    reboot
    This now allowed me to run  the script shown in the video on the push of a button or from a crontab!
    Rene is a very experienxed UNIX/Linux Guy so I also share his tip here that might come in handy for screen recording:
    do you know how to enlarge the font size for the console on the Rasperry ?
    sudo dpkg-reconfigure console-setup
    search for terminus font ;-) and a larger pixel ;-) this makes it more readable on a high-res monitor ;-)
    A Big thank you to Rene for sharing his knowledges with us!
  • mayermakes
    the preface Airplane
    Its only getting the orders that are ready for shipping and helps packing these orders one by one by matching barcodes.
    So the whole station has only one purpose: packing orders. nothing else.
    Focus on one specific task is the intended approach to avoid packing errors.
    The backend is a Webserver running Woocommerce and dokan with a few plugins and customizations (mainly for compliancy with GPDR/Commerce laws)
    so a lot of databases with MySQL behind it.
    So all the databases and connections you mentioned are there and mostly operational (I have recently nuked the build to rebuild it without legacy residue)
    How do you add a part:
    Simple you can use the full extend of the Dokan API and Woocommerce Rest API or just enter it on the Website if you don't want to do it automated.
    Also some settings are not accessible via API because pushing them in  would break compatibility with security updates pushed by maintainers of the main repos.
    here is some documentation: https://wedevsofficial.github.io/dokan/
    In there are code variants for php, JS, python, bash, and ruby.
    the User interface can therefore be whatever code you want to write or just the website.
    Which of course you can use with Keyboard and mouse.
    the barcode reader is only there for the packing station as shown in the video.
  • phoenixcomm
    phoenixcomm over 4 years ago
    clem, I personally don't like your warehouse system, mine took me about 6 months of programming in Perl, a C-like language suited for strings, and I don't like python. I personally think you missed the boat. everything in a bar-code.LOL, my large online DB is punished published with MySQL.  www.phoenixtrading.biz currently, I have over 1/4 million records, I, in fact, you have two parts the Info table which has all the stuff about the product. and a link to the manufactures table. Second or third you need your history table, invoice table, and quotes which turn into invoices. If you go further you need a purchasing table.
    how do you add a part?? Description, etc with a barcode?
    I use Apache as the user interface.
  • kmikemoo
    DAB over 4 years ago
    Nice episode Clem.
  • mayermakes
