Project Videos
  • Project Videos
Project Videos
Documents Build a Phonograph Preamplifier - How Hard Can It Be? -- Episode 537
  • Author Author: kellyhensen
  • Date Created: 2 Feb 2022 3:00 PM Date Created
  • Last Updated Last Updated: 11 Feb 2022 8:24 AM
  • Views 11995 views
Like many of our hosts, Matthew is an aficionado of vintage technology. In this project, Matthew is completely rebuilding a Califone 1400 series portable phonograph from the early 1980s to improve its playback quality. The first obstacle he has to overcome is rebuilding the preamplifier circuit to bring the raw phono signals from the tonearm up to RIAA line level, but he's having a little trouble with the op-amp chip. How hard could it be to build a simple preamp from scratch?
Supplemental Content:
  • Single Stage, Single Channel Phono Preamp With Power Supply Schematic
Bill of Materials
NE5532AP OP AMP, DUAL LOW NOISE, 5532, DIP8 TI 1 Buy Now
WAU12-1000 AC/AC Power Supply, External Plug In, Fixed, 1 Output, 120 VAC, 12 W, 12 VAC, 1 A Triad Magnetics 1 Buy Now
1N4002+ Standard Recovery Diode, 100 V, 1 A, Single, 1.1 V, 30 A MULTICOMP PRO 2 Buy Now
MCF 0.25W 100R Through Hole Resistor, 100 ohm, MCF Series, 250 mW, ± 5%, Axial Leaded, 250 V MULTICOMP PRO 2 Buy Now
ECA-1CM101B Electrolytic Capacitor, 100 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C, Polar Panasonic 2 Buy Now
element14 presents
element14 presents  |  About Matt |  Project Videos
  • airbornesurfer
  • opampsch
  • Califone record player rebuild
  • DIY amplifier power supply
  • DIY preamp power supply
  • matt eargle
  • Califone 1430k
  • e14p_MAS
  • Califone phonograph
  • DIY phono preamp
  • friday_release
  • opamp power supply
  • califone record player
    DAB over 4 years ago +2
    Very entertaining. That said, there are a lot of issues to building a GOOD audio amplifier. Also, your power lines must be very clean or they will introduce unwanted noise into the audio. I think…
  • michaelkellett
    michaelkellett over 4 years ago in reply to airbornesurfer
    Will eventually be relevant to your project !
    community.element14.com/.../audio-measuring-system-based-on-hp-8903a
  • airbornesurfer
    airbornesurfer over 4 years ago in reply to DAB
    Yes, indeed! This is, of course, just proof of concept ("It's only a prototype!"), but you are quite correct that it is one thing to build an amplifier and another thing to build a good amplifier! I'm still working on the project (the bulk of this video was shot over a year ago now), and I've got a pretty decent preamp going (it doesn't sound like trash anymore). I'll post an update soon.
    Very entertaining.
    I think you have a way to go before you get to where you want to be, but if you take your time and study what goes into a good audio amplifier, you can indeed get there.
