Project Videos
  • Project Videos
Project Videos
Documents Electronic Fidget Cube, Building Your Ideas! -- Episode 548
  • Date Created: 20 Apr 2022 8:40 PM Date Created
  • Last Updated Last Updated: 29 Apr 2022 7:24 AM
  • Views 604772 views
So half a fidget cube is fun, but a whole fidget cube is even better! Join me for part 2 where we look at the remaining 3 sides of the cube.
Supplemental Content:
  • GitHub: https://github.com/hifromkatie/Fidget-Cube
  • Resources
Bill of Materials
AVR64DA32-I/PT MICROCHIP AVR Microcontroller, AVR DA Family AVR64DA Series Microcontrollers, AVR, 8bit, 24 MHz, 64 KB MICROCHIP 5 Buy Now
PG164100 MICROCHIP Debugger/Programmer, MPLAB Snap, In-Circuit, For PIC, dsPIC, AVR Flash MCUs MICROCHIP 1 Buy Now
53398-0271 MOLEX Pin Header, Wire-to-Board, 1.25 mm, 1 Rows, 2 Contacts, Surface Mount Straight MOLEX 12 Buy Now
53398-0371 MOLEX Pin Header, Vertical, Signal, 1.25 mm, 1 Rows, 3 Contacts, Surface Mount Straight MOLEX 1 Buy Now
15134-0200 MOLEX Cable Assembly, PicoBlade Receptacle to PicoBlade Receptacle, 2 Ways, 1.25 mm, 1 Row, 50 mm, 2 " MOLEX 5 Buy Now
MAX16054AZT+T MAXIM INTEGRATED PRODUCTS Push Button On/Off Controller with Debouncer, Latched Output, 2.7V to 5.5V, TSOT-23-6 MAXIM 2 Buy Now
MCOT128064P1V-WM MIDAS Graphic OLED, 128 x 64 Pixels, White on Black, 3V, I2C, Parallel, SPI, 34.5mm x 23mm, -40 °C MIDAS 1 Buy Now
MCMT5-F-V MULTICOMP PRO Navigation Switch, 1.57 N, 12 V, 50 mA, Solder, 4 MULTICOMP PRO 1 Buy Now
SKSTAAE010 ALPS ALPINE Tactile Switch, SKST Series, Top Actuated, Surface Mount, Round Button, 400 gf, 50mA at 16VDC ALPS ALPINE 2 Buy Now
MSLPT5252BG4MTR ALCOSWITCH - TE CONNECTIVITY Tactile Switch, MSLPT Series, Top Actuated, Surface Mount, Round Button, 260 gf, 50mA at 12VDC ALCOSWITCH - TE CONNECTIVITY 6 Buy Now
JSX08001SAQNL C&K COMPONENTS Slide Switch, SPDT, Momentary Spring Return, Surface Mount, 10 mA C&K COMPONENTS 1 Buy Now
434121025816 WURTH ELEKTRONIK Tactile Switch, WS-TASV Series, Top Actuated, Surface Mount, Round Button, 160 gf, 50mA at 12VDC WURTH ELEKTRONIK 5 Buy Now
PMN48XPA2X NEXPERIA Power MOSFET, P Channel, 20 V, 4.4 A, 0.037 ohm, TSOP, Surface Mount NEXPERIA 2 Buy Now
MAX1675EUA+T MAXIM INTEGRATED PRODUCTS DC-DC Switching Sync-Boost (Step Up)Regulator, Adj, 700mV-5.5Vin, 3.3V-5V/300mA out, 500 kHz, µMAX-8 MAXIM INTEGRATED PRODUCTS 1 Buy Now
MC33275ST-3.0T3G ONSEMI LDO Voltage Regulator, AEC-Q100, Fixed, up to 13 V in, 260 mV drop, 3 V/300 mA out, SOT-223-4 ONSEMI 1 Buy Now
LQH43NH220J03L MURATA Wirewound Inductor, 22 µH, 0.564 ohm, 15 MHz, 300 mA, 1812 [4532 Metric], LQH43NH_03 Series MURATA 1 Buy Now
599-0230-007F DIALIGHT LED, Orange, SMD, 1206 [3216 Metric], 20 mA, 2.1 V, 605 nm DIALIGHT 2 Buy Now
599-0210-007F DIALIGHT LED, Red, SMD, 1206 [3216 Metric], 20 mA, 2.1 V, 633 nm DIALIGHT 2 Buy Now
599-0291-007F DIALIGHT LED, Blue, SMD, 1206 [3216 Metric], 20 mA, 3.2 V, 470 nm DIALIGHT 2 Buy Now
599-0281-007F DIALIGHT LED, Green, SMD, 1206 [3216 Metric], 20 mA, 3.2 V, 525 nm DIALIGHT 2 Buy Now
MC011368 MULTICOMP PRO LED, Orange Red, SMD, 0805 [2012 Metric], 20 mA, 2.1 V, 620 nm MULTICOMP PRO 7 Buy Now
MP000443 MULTICOMP PRO LED, Green, SMD, 0805 [2012 Metric], 20 mA, 3.1 V, 525 nm MULTICOMP PRO 7 Buy Now
KPHCM-2012SYCK KINGBRIGHT LED, Low Power, Yellow, SMD, 0805 [2012 Metric], 20 mA, 2 V, 590 nm KINGBRIGHT 2 Buy Now
MULTICOMP PRO 3D Printer Filament, 2.85mm Dia, Black, PLA, 1 kg MULTICOMP PRO 1 Buy Now
DFROBOT Educational & Maker Kit, 4-Soldering Light Chaser Beam Robot DFROBOT 1 Buy Now
MIDAS Graphic OLED, 128 x 128 Pixels, White on Black, 3V, I2C, Parallel, SPI, 33.8mm x 36.5mm, -40 °C MIDAS 1 Buy Now
DFROBOT Triple Axis Accelerometer, BMA220 (Tiny), For Arduino UNO/arduino Leonardo Boards DFROBOT 1 Buy Now
MOLEX FFC / FPC Board Connector, R/A, 0.5 mm, 24 Contacts, Receptacle, Easy-On 502244, Surface Mount MOLEX 1 Buy Now
Additional Parts:
Lego Spike Prime set
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • Fidget
  • buttons
  • e14p_KD
  • neopixels
  • fidget cube
  • Small Circuits
  • leds
  • katie
  • friday_release
  • Electronics Cube
  • mayermakes
    mayermakes over 4 years ago
    Finaly conclusion to this project! very cool use of some parts I havn't dared to try out yet!
  • hifromkatie
    hifromkatie over 4 years ago in reply to mayermakes
    Thanks, it's been nice to finish it off.
    Still hoping to get back to the third side and try to get it to work correctly.
  • hifromkatie
