Project Videos
  • Project Videos
Project Videos
Documents Arduino Uno Mini Limited Edition LED Necklace -- Episode 554
  • Date Created: 31 May 2022 4:40 PM Date Created
  • Last Updated Last Updated: 10 Jun 2022 7:24 AM
  • Views 178240 views
  • Comments 16 comments
Katie got herself a limited edition Arduino Uno Mini Gold board, and she started thinking about her options for using it. Stick it on a shelf, keep it safe in a box, put it inside a project where it can’t be seen, or ..... make a feature of it, and build it into a piece of wearable electronics! She decides on the last option, working on a tech-y necklace featuring NeoPixels and more.
Supplemental Content:
  • GitHub:  https://github.com/hifromkatie/UnoMiniWearable
  • Episode 554 Resources
Bill of Materials
ARDUINO ARDUINO UNO MINI GOLD DEV BOARD ARDUINO 1 Buy Now
ADAFRUIT PowerBoost 1000 LiPo Charger 5V 1A Boost ADAFRUIT 1 Buy Now
ADAFRUIT Light Strip Length:1m ADAFRUIT 1 Buy Now
C&K COMPONENTS Slide Switch, SPDT, On-On, Through Hole, 1000, 6 A, 250 V C&K COMPONENTS 1 Buy Now
TR FASTENINGS Socket Screw, Cap, Hex Socket, Stainless Steel, 12 mm, M3, Pack of 50 TR FASTENINGS 13 Buy Now
TR FASTENINGS Socket Screw, Cap, Hex Socket, Stainless Steel, 8 mm, M3, Pack of 50 TR FASTENINGS 3 Buy Now
M3-UHBRHESF Insert, Blind, Heat-SertTm, Brass, Unheaded, 5.8mm x 4.4mm, M3, Pack of 100 TR FASTENINGS 11 Buy Now
Accessory Type:Magnetic Pin ADAFRUIT 1 Buy Now
Additional Parts:
LiPo Battery 500mAh
3D printer filament to suit your printer
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • e14p_KD
  • neopixels
  • Arduino Uno Mini Limited Edition
  • Rainbows
  • arduino uno mini
  • katie
  • Wearables
  • friday_release
    beacon_dave over 4 years ago +1
    You could perhaps try fitting it with a wristband and wear it as a corsage. Perfect for getting noticed at that prom... Optionally get those LED pixels synchronised to the music or the heartbeat...
  • kmikemoo
    kmikemoo over 4 years ago
    hifromkatie  Awesome project.  I love your creativity.  Being able to showcase the Uno Mini Gold is brilliant!  I also have boxes with older Raspberry Pi's and Arduinos.  I have enough now that I should be tying to find them more "permanent homes" - aka projects that I'm so happy with how it turned out that I'm not likely to tear it apart for the very next "great idea".
  • kmikemoo
  • hifromkatie
    hifromkatie over 4 years ago in reply to kmikemoo
    Glad you also thought it was a good way to showcase the board.
    I've got another box of Arduino shields, a couple boxes of pi hats etc, boxes of unstarted projects and a few full of all the parts required to actually start a project, but which are probably now out of date and would be better done with newer components. at least the boxes stack.
