Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Controlled Lego Train with Build HAT -- Episode 560
  • Date Created: 20 Jul 2022 7:50 PM Date Created
  • Last Updated Last Updated: 22 Jul 2022 7:24 AM
  • Views 298631 views
  • Comments 12 comments
So, the Duplo train can be automated using coloured tiles, but the Lego train can’t… Until now. With a Raspberry Pi, a build Hat and the Lego train Motor 88011, Let's modify the Lego Hogwarts Express Train (Set 75955) to run autonomously using coloured Lego tiles!
Supplemental Content:
  • Link to the Github:  https://github.com/hifromkatie/LegoTrain
  • Resources_560.zip
Bill of Material:
RPI4-MODBP-4GB - Raspberry Pi 4 Model B RASPBERRY-PI 1 Buy Now
16GB MicroSD Card with NOOBS for Raspberry Pi TRANSCEND 1 Buy Now
SC0622 RASPBERRY PI BUILD HAT RASPBERRY-PI 1 Buy Now
8459-0674 BATTERY STRAP, 9V, WIRE LEAD MULTICOMP PRO 1 Buy Now
BUD INDUSTRIES Battery Retainer Clip, PP3 (9V) x 1, Through Hole, Wire Leads BUD INDUSTRIES 1 Buy Now
CLIFF ELECTRONIC COMPONENTS DC Power Connector, Plug, 2 A, 2.1 mm, 9.5 mm, Cable Mount, Solder CLIFF ELECTRONIC COMPONENTS 1 Buy Now
MULTICOMP PRO Rechargeable Battery, 1.2 V, Nickel Metal Hydride, 2.6 Ah, AA, Raised Positive and Flat Negative MULTICOMP PRO 2 Buy Now
1356 Color Sensor, Flora, White Illumination LED ADAFRUIT 1 Buy Now
Additional Parts:
Lego HogwartsTM Express Train – 75955
Train Motor V46 – 88011
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • rpi 4
  • LEGO
  • color sensing
  • harry potter
  • raspberrypi
  • katie
  • Build Hat
  • e14p_katie
  • friday_release
    beacon_dave over 4 years ago
    I seem to recall that the original Lego train sets (blue rails with white sleepers) had a reversing lever on the side of the tender battery box which struck a reversing post (red?) placed at the side of the rails. There was also a motor stop button on the underside of the train motor that interacted with the signals which raised and lowered a skid in the centre of the track. No sound effects back then, you had to do that yourselves...
  • hifromkatie
    hifromkatie over 4 years ago in reply to beacon_dave
    Oh awesome, I've seen that generation of the Lego trains (in pictures & videos), but never seen it stop like that, so hadn't realised it had a button under the tender. Thanks for sharing
  • hifromkatie
    beacon_dave over 4 years ago in reply to hifromkatie
    If I recall correctly, the earlier trains started out using the standard Lego battery box mounted on wheels so lacked the functionality of the signal stop and the reversing post.
    I think the 122 set was the first train I had which was like that:
    https://youtu.be/TGiWWMXjIjY?t=102
    It was unusual as it could also run off the rails by using the alternative supplied wheels or caterpillar tracks.
    I think the track may have been sold separately from the train as I can recall it coming in individual track boxes of straight and curved sections, but it was probably sold as a train plus track layout bundle from the toy shops to fit the budget/space.
    The 181/182 train sets were probably some of the earlier ones to incorporate a purpose-built battery box tender with the added control functionality. I guess that the control was needed once sets with sidings and points were marketed to prevent runaway trains and collisions from happening.
  • hifromkatie
    Great info, I didn't know all that. Thanks
    Another bit of trivia that I can recall is that the earlier trains had fine teeth cut into the wheels which meshed with fine teeth cut into the top edge of the rails (only one of the curved rails had teeth, outer I think, the other rail was smooth on top). The later trains had smooth wheels but the driven wheels had rubber bands fitted for traction.
    If you look closely in the above two videos you might be able to see this.
    Not sure what they did when the rails transitioned from blue to grey though.
