Project Videos
  • Project Videos
Project Videos
Documents Pi Home Temperature Monitoring System -- Episode 562
  • Date Created: 21 Jul 2022 3:36 PM Date Created
  • Last Updated Last Updated: 5 Aug 2022 7:24 AM
  • Views 499998 views
  • Likes 9 likes
To enable analysis of temperatures around the house, Andy built a monitoring system consisting of remote sensors and a centralised dashboard using Mosquitto MQTT Broker, Influx DB a time series database, Node Red the visual programming tool for the Internet of Things, and Grafana for charting and graphs.
Supplemental Content:
  • Code and 3d models
  • Workbench Wednesdays 56: How to Profile Battery Usage for IoT Devices
Bill of Material:
Pi Pico Raspberry Pi 4 Buy Now
ESP8266 WiFi Serial Transceiver Module Breakout Board Seeed Studio 4 Buy Now
Lipo Shim Pimoroni 4 Buy Now
DHT11 DF Robot 4 Buy Now
Tactile Switch ALCOSWITCH - TE CONNECTIVITY 4 Buy Now
0.1" Pin Header, 20 Way, 10 Pack Harwin 1 Buy Now
PCB Receptacle, Board-to-Board, 2.54 mm, 2 Rows, 8 Contacts, Through Hole Mount MULTICOMP PRO / AMPHENOL COMMUNICATIONS SOLUTIONS 4 Buy Now
Lipo Battery MIKROELEKTRONIKA / Adafruit 4 Buy Now
IP65 Polypropylene Enclosure - 110x110x65mm - ETERNA 1 Buy Now
Raspberry Pi 4 Raspberry Pi 1 Buy Now
Additional Parts:
Pico Zero Expansion Board (4)
USB to Sata adapter
SDCard
ATX Powersupply
MDF
Metal Mesh
Paint
3D Printer Filament
element14 presents
element14 presents  |  Andy's Profile   |  Project Videos
  • wifi
  • mqtt
  • Andy Clark
  • temperature
  • battery
  • raspberry pi
  • e14p_AC
  • friday_release
  • pi pico
  • Andy
  • Workshopshed
    Workshopshed over 3 years ago in reply to itpilot
    The code is designed remote sensors attached to the PiPico not directly connected to the Pi4.
    Looking at the Arduino DHT11 library code, I suggest allocating one pin per device. And then creating multiple DHT objects which you could read in turn. You'd also want to update the message to be unique for each sensor.
    If you wanted to use directly attached sensors this could also work, you could either mash up a python example for the temperature sensors and Matt and have it work the same as existing sensors.
    www.raspberrypi-spy.co.uk/.../
    Or you could cut out a step and read the sensors directly in NodeRed. Although I think that might require running NodeRed directly on the Pi rather than in a docker container.
    flows.nodered.org/.../node-red-contrib-dht-sensor
  • itpilot
    itpilot over 3 years ago
    Very nice project
    I need to connect 3 x DHT22 Temperature and Humidity Sensors to my Raspberry PI 4
    Where in the Code do I add the Additional DHT22 Sensors as i have them connected to required GPIO Pins on the Raspberry PI 4
  • Workshopshed
    Workshopshed over 4 years ago
    Link for the code and wiring - github.com/.../RemoteTemperatureMonitoring
    DAB over 4 years ago
    Nice build Andy.
