Project Videos
  • Project Videos
Project Videos
Documents How to Automate Industrial Welding Positioners with Arduino -- Episode 566
  • Date Created: 11 Aug 2022 5:03 PM Date Created
  • Last Updated Last Updated: 2 Sep 2022 7:24 AM
  • Views 467472 views
  • Comments 15 comments
In this episode we are looking at a couple of welding positioners that I worked on. Retrofitting one from an old lost PLC to arduino, and another built from scratch. Both of these devices are designed for use with a TIG welder. The rotary positioner puts the work where you need it, and the linear positioner holds the torch and moves it in a precise line to get perfect dimes!
Bill of Material:
Arduino UNO Arduino 2 Buy Now
Toggle Switch EATON 2 Buy Now
Rotary Encoder Bourns 1 Buy Now
Power Supply XP Power 2 Buy Now
Additional Parts:
3v Relay Module
8ch Optoisolator
NEMA 34 Stepper Motor
NEMA 32 Stepper Motor Driver
20x4 I2C LCD Display Module
Arduino UNO Screw Terminal Breakout Board
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • welding
  • diy
  • TIG
  • Welder
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to kmikemoo +1
    That is interesting, I did not know about that. I have some other projects that are going to be near TIG welders coming up, I will have to give this a shot. The interference was able to put enough voltage…
  • KalebTheMaker
    KalebTheMaker over 4 years ago +1
    One thing I forgot to mention in the video is how the system was grounded. I'll try to explain. When this shop was built, the guy that owns it built a steel mesh into the concrete with 3/4" threaded…
  • Workshopshed
    Workshopshed over 4 years ago
    I wonder if a couple of Canbus modules would be sufficient to protect the signals from the remote pendant?
  • kmikemoo
    kmikemoo over 4 years ago in reply to Workshopshed
    I think CAN would work.  It functions near vehicle ignition systems.  Those can be pretty noisy.  My first thought was MODBUS as the RS-485 also uses a differential pair.  You can also get shielded, twisted-shielded wire for high noise environments.  If it's a longer run, CAN is probably the best solution. Thumbsup
  • kmikemoo
