Project Videos
  • Project Videos
Project Videos
Documents How to Automate Industrial Welding Positioners with Arduino -- Episode 566
  • Date Created: 11 Aug 2022 5:03 PM Date Created
  • Last Updated Last Updated: 2 Sep 2022 7:24 AM
  • Views 467480 views
  • Comments 15 comments
In this episode we are looking at a couple of welding positioners that I worked on. Retrofitting one from an old lost PLC to arduino, and another built from scratch. Both of these devices are designed for use with a TIG welder. The rotary positioner puts the work where you need it, and the linear positioner holds the torch and moves it in a precise line to get perfect dimes!
Bill of Material:
Arduino UNO Arduino 2 Buy Now
Toggle Switch EATON 2 Buy Now
Rotary Encoder Bourns 1 Buy Now
Power Supply XP Power 2 Buy Now
Additional Parts:
3v Relay Module
8ch Optoisolator
NEMA 34 Stepper Motor
NEMA 32 Stepper Motor Driver
20x4 I2C LCD Display Module
Arduino UNO Screw Terminal Breakout Board
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • welding
  • diy
  • TIG
  • Welder
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to kmikemoo +1
    That is interesting, I did not know about that. I have some other projects that are going to be near TIG welders coming up, I will have to give this a shot. The interference was able to put enough voltage…
  • KalebTheMaker
    KalebTheMaker over 4 years ago +1
    One thing I forgot to mention in the video is how the system was grounded. I'll try to explain. When this shop was built, the guy that owns it built a steel mesh into the concrete with 3/4" threaded…
  • fmilburn
    fmilburn over 4 years ago
    Very interesting projects! I admit to not understanding all the issues you were facing. Was the Arduino optically isolated on all pins and fully shielded? It would seem not. Would disabling interrupts during the time the TIG was firing, assuming that it fires intermittently, help?
  • fmilburn
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to fmilburn
    Yes, I had an opto isolator for all input pins, and the enclosure was completely shielded. That's an interesting idea to disable inputs while the TIG was firing, but I just did not have time to do any creative troubleshooting (and I am not sure that I would have thought of that anyway. haha)
