Project Videos
  • Project Videos
Project Videos
Documents How to Make a Custom Soundboard with the STM32F4 using FreeCAD -- Episode 568
  • Date Created: 23 Aug 2022 8:38 PM Date Created
  • Last Updated Last Updated: 16 Sep 2022 7:24 AM
  • Views 130577 views
  • Likes 8 likes
  • Comments 10 comments
Help! Our band needs a sound effect to be played, quickly and with minimal fuss. So why not make a custom box to be on hand for anytime a sound effect is needed. With an STM32 microcontroller and a speaker I set out to make a box to do just that.
Supplemental Content:
  • Link to the Github:  https://github.com/hifromkatie/SoundEffectInstrument
  • Episode 568: Resources
Bill of Material:
STMICROELECTRONICS Development Kit, STM32F412ZG MCU, ST-LINK/V2-1 Debugger/Programmer, 240x240 Pixel TFT color LCD STMICROELECTRONICS 1 Buy Now
ADAFRUIT 20W AMPLIFIER KIT MAX9744 68X4713 ADAFRUIT 1 Buy Now
MIDAS Graphic OLED, 128 x 32 Pixels, White on Black, 3V, SPI, 32.5mm x 20.5mm, -40 °C MIDAS 4 Buy Now
HERGA Foot Operated Switch, 6289, SPCO, 6 A, 250 V, 24 mm HERGA 1 Buy Now
MULTICOMP PRO Pushbutton Switch, 20.2 mm, DPST, Off-(On), Round Raised, Black MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Pushbutton Switch, R13-24, 7.2 mm, SPST-NO, Off-(On), Round, Black MULTICOMP PRO 4 Buy Now
STMICROELECTRONICS Linear Voltage Regulator, Fixed, Positive, 10V To 35V In, 5V And 2A Out, TO-220-3 STMICROELECTRONICS 1 Buy Now
MULTICOMP PRO AC/DC Power Supply, Level VI, ITE, 1 Output, 24 W, 12 V, 2 A MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Plastic Enclosure, Desktop Case, Instrument, ABS, 250 mm, 180 mm, 100 mm MULTICOMP PRO 1 Buy Now
ADASTRA 3" Weatherproof Speaker White, 100V / 8 Ohm - 30W RMS ADASTRA 1 Buy Now
2.1MM DC SOCKET PRO POWER 1 Buy Now
LUMBERG Circular Connector, 03 Series, Cable Mount Plug, 3 Contacts, Solder Pin, Threaded LUMBERG 1 Buy Now
LUMBERG Circular Connector, 03 Series, Panel Mount Receptacle, 3 Contacts, Solder Socket LUMBERG 1 Buy Now
LUMBERG Circular Connector, 03 Series, Cable Mount Receptacle, 4 Contacts, Solder Socket, Threaded LUMBERG 1 Buy Now
LUMBERG Circular Connector, 03 Series, Panel Mount Plug, 4 Contacts, Solder Pin LUMBERG 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • band
  • e14p_KD
  • stm32
  • sound
  • music
  • sound effects
  • friday_release
  • instrument
    dougw over 4 years ago
    Great build - what is the maximum duration of a sound?
  • hifromkatie
    hifromkatie over 4 years ago in reply to dougw
    I think it'll be defined by the file size limit, so 10mins+, it blocks whilst playing, so you couldn't play a second sound over the top of an already playing sound though. Could be changed to mix sounds I'd imagine though.
  • hifromkatie
