Project Videos
  • Project Videos
Project Videos
Documents Using Dead Batteries to Test for Dead Batteries -- Episode 571
  • Date Created: 8 Sep 2022 8:29 PM Date Created
  • Last Updated Last Updated: 27 Nov 2023 10:35 AM
  • Views 119731 views
  • Likes 9 likes
  • Comments 24 comments
Dead battery? That's a matter of perspective! Instead of recycling coin cell batteries when their time is due, I will put them to good use and show you a secret feature of a Raspberry Pi Pico - and what sets it apart from other microcontrollers. Let's use the dead batteries to check for dead batteries, so I never have to doubt the battery again! I'll end up with a nifty box to keep my batteries organised, tested, and ready to use!
Watch the Video
Code and 3D Models
  • Episode 571 Resources
Bill of Materials
Raspberry Pi Pico RASPBERRY PI 1 Buy Now
0.96" I2C Display MIDAS 1 Buy Now
10k resistor MULTICOMP PRO 1 Buy Now
IN4007 diode NTE ELECTRONICS 1 Buy Now
CR2032 battery holder MULTICOMP PRO 1 Buy Now
Switch OMRON 1 Buy Now
element14 presents
element14 presents  |  About Mat Z |  Project Videos
  • how to test batteries
  • e14p_MZ
  • voltage measurements
  • friday_release
  • Pico battery tester
    beacon_dave over 4 years ago +2
    Perhaps you could use Karen's 'juicer' to extend the life of those dead batteries even further? /challenges-projects/element14-presents/thelearningcircuit/w/documents/4041/the-learning-circuit-39-inductor…
  • notenoughtech
    notenoughtech over 4 years ago in reply to phoenixcomm +1
    Thank you
    beacon_dave over 2 years ago in reply to PingWinko +1
    The stl files are in the download available here: /challenges-projects/element14-presents/m/files/146732 Click the 'Download' button on the page. ( tariq.ahmad the resources link above needs…
  • phoenixcomm
    phoenixcomm over 4 years ago
    This is neat!!
  • notenoughtech
    Thank you  Slight smile
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to notenoughtech
    I am working on my own printer volume is ~24 cubic inches. The nice part about the printer is once you level the frame, then you level the bed. (it never ever moves.) the only thing that moves is the gantry which moves with two steppers one on each side. Side to side and up and down are controlled by two more steppers for a total of 4. the gantry checks at the four corners before printing and will not move if the bed needs adjustment. the frame and the device to hold the bed are STEEL tig welded. as well as the gantry which takes about 6" per each of the two feet.
    The reason I am taking this approach is that the machine will have three heads. Printer, Laser Engraver, CNC Spindel( most likely I will just do plastics.)
  • notenoughtech
    That sounds interesting, hope you'll share some pictures :)
  • notenoughtech
