Project Videos
  • Project Videos
Project Videos
Documents Ghost Rider Halloween Costume -- Episode 574
  • Date Created: 25 Oct 2022 3:17 PM Date Created
  • Last Updated Last Updated: 28 Oct 2022 7:24 AM
  • Views 147752 views
  • Likes 8 likes
  • Comments 11 comments
It was a dark and stormy night, a lone engineer was prototyping in their workshop. For this Halloween Special, Andy combines a range of effects to make flames and a glowing skull, all triggered by a motion activated remote control.
Watch the Video:
Bill of Material:
Arduino Nano 33 BLE Arduino 2 Buy Now
DC Axial Fan Multicomp 2 Buy Now
DC Motor Driver, TB6612FNG DF Robot 1 Buy Now
LED Red 10mm KingBright 4 Buy Now
LED Yellow 10mm KingBright 2 Buy Now
Prototyping Board CIF 1 Buy Now
Additional Material:
Skull Mask
Leather Jacket
Fake Chain
Silver/Grey 3D Printer Filament
Strong Magnets (2)
Thin red cloth
Adafruit 3W Neopixel Module (2)
element14 presents
element14 presents  |  Andy's Profile   |  Project Videos
  • ble
  • halloween
  • dc motor driver
  • leds
  • flames
  • nano 33 ble
  • Ghost Rider
  • e14p_AC
  • friday_release
  • fans
  • robogary
    robogary over 4 years ago +1
    A hot project :-) I really enjoyed how it grew and got strapped into a backpack.....all my projects start out small and with workscope-creep, need a truck when Im done. :-)
    Jan Cumps over 4 years ago in reply to dougw
    Spooky things happen at Halloween
    dougw over 4 years ago in reply to Jan Cumps
    It is funny that the email notification of this comment had a different embedded image....Alien
    DAB over 4 years ago
    Very good build.
  • robogary
    robogary over 4 years ago in reply to Workshopshed
    Fans usually specify cfm or c-in/min. I'd considered using a 12v plug in windshield defroster for a blower style flame effect (disconnecting the heater element) on projects. I've opted to use led flame bulbs in those type of projects.the bulbs can be opened, and the led sheet inside can be unfurled to make a flat screen flame effect if desired. Your choice is best in your case as it is not so dependent on viewing angle.
  • Workshopshed
    Workshopshed over 4 years ago in reply to Workshopshed
    The NRF52840-DONGLE might also work
  • Workshopshed
    I wonder if there is an easy solution to the lack of PWM outputs when using Arduino with the Nano 33 BLE, the underlying chip should be capable of doing this, it has 3 PWM modules with 4 outputs each. A similar board is the Adafruit ItsyBitsy nRF52840 Express which might be the answer for the main board and perhaps Seeed XIAO BLE nRF52840 for the remote. I had originally picked the same boards for both remote and main to avoid having communications challenges.
  • Workshopshed
    Workshopshed over 4 years ago in reply to robogary
    I knew the super small fall wasn't going to be enough but the next size up seemed like it was going to work. Not sure if it was my 3D printed channel that stopped it working or if it was because I went a little bit bigger on the flames. Luckily I had some big fans that worked on 12v, but would have preferred the blower style if I'd have had ones with the right flow rate. There's probably a way of estimating flow rate based on diameter and rpm but the fan blade geometry likely also affects things.
  • robogary
    The video storyline was good too
  • robogary
