Project Videos
  • Project Videos
Project Videos
Documents How to Make a Secured Parcel Pickup Box with Arduino -- Episode 575
  • Date Created: 31 Oct 2022 6:15 PM Date Created
  • Last Updated Last Updated: 4 Nov 2022 8:24 AM
  • Views 132660 views
  • Comments 10 comments
Everyone knows the dreaded feeling of having to pick up your parcel full of project parts from the Couriers pickup station, but at least it arrived! Being able to do that around the clock without worrying what time the shop opens is pretty convenient.  Clem sells stuff online and local customers like to save on shipping costs by picking the items up in person. Since Clem can't be available 24/7 he decided to build an open source electronic pickup box. A 6 digit code sent via email is all the customer needs to get the desired item from the box! Powered by an Arduino Leonardo and wrapped in a convenient easy to use shield, this should enable anyone to build their own pickup box for various tasks.
Watch the Video:
Supplemental Content:
  • Episode 575 Resources
Bill of Material:
"SCHNEIDER ELECTRIC Metal Enclosure SCHNEIDER ELECTRIC 1 Buy Now
"DFROBOT Battery Holder DFROBOT optional Buy Now
"PANASONIC Solid State Relay PANASONIC AC variant Buy Now
3V relay PANASONIC 1 Buy Now
"ARDUINO leonardo Development Board Arduino 1 Buy Now
"MULTICOMP 3D Printer Filament MULTICOMP 1 Buy Now
Additional Parts:
Keypad shield pcb – files in the downloads
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • keypad
  • arduino leonardo
  • pick up
  • diy
  • e14presents_CM
  • open source
  • friday_release
  • mayermakes
    mayermakes over 4 years ago +1
    What are your ideas for making the Relay driving better, and did you spot some weaknesses on security? let me know down below.
    dougw over 4 years ago in reply to mayermakes +1
    I don't know how big your solenoid is but a 1N5400 across the solenoid is probably fine - they can stand a surge current up to 200A. I have different FETs for different applications, the FET you need…
  • baldengineer
    baldengineer over 4 years ago +1
    I like the overall design. I could also see such a lockbox in a workshop to limit access to tools or materials. It won't stop someone that REALLY wants to get in, but it also provides some basic access…
  • mayermakes
    mayermakes over 4 years ago in reply to baldengineer
    I agree with al lthese points, the things that makes soldi state relays trippy is that they correctly switch on from a reset, but never deactivate, which makes debugging stupidly nervwrecking when you don't know whats going on.
  • baldengineer
    It won't stop someone that REALLY wants to get in, but it also provides some basic access control with a potential for logging.
    Other additions I would consider: NFC reader (especially for owner access), battery backup, and WiFi for remote access/logging.
    Bummer about the solid state relay. I highly doubt you're the only one who didn't realize they require an AC waveform to work correctly. (They're basically just an SCR.) But, good job past-Clem for designing a mechanical relay footprint!
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    thanks DAB
    DAB over 4 years ago
    Good build Clem.
  • mayermakes
    mayermakes over 4 years ago in reply to dougw
    thanks! mentioning the deciding factors of apart, in addition to a specific part is really valuable to understand the choice!
    I have different FETs for different applications, the FET you need should have a low on resistance so i x i x R < 0.3W where i is the current in your solenoid. The gate threshold voltage needs to be very low (about 1.5V) so the FET has low resistance when the gate has a digital high output. Something like IRF7809AVTRPBF should work.
  • mayermakes
    I knew I could count on you for knowing the propper way to do this! I briefly thought about using a Mosfet, but kinda got distracted by the small relay listing...
    specing the snubber diode is something I never did.
    Do you have a go to NFET and Diode for such an application?
    I would just use a big NFET on the low side of the solenoid with a snubber diode across the solenoid. Because a FET can be driven directly by a digital output.
    You might need a way to open the door if the electronics fail. Maybe a normal key access.
    Of course the box would need to be physically secured so they don't take the whole box.
    If gets to the product stage, the internal stuff would be in an enclosed compartment.
    Cool idea. There are some suppliers around here that could use it.
  • mayermakes
