Project Videos
  • Project Videos
Project Videos
Documents The Game Guy Mini, Upgrading the Unportable Game Boy! -- Episode 577
  • Date Created: 3 Nov 2022 3:34 PM Date Created
  • Last Updated Last Updated: 18 Nov 2022 8:24 AM
  • Views 22923 views
  • Likes 11 likes
  • Comments 30 comments
element14 Community member Joe Ostrander saw the "Unportable Game Boy" that Andy made in a previous video, and decided to make a new and improved version. In this episode, Andy builds a console from Joe's upgraded design and demonstrates its features, including several enhancements that were requested by viewers.
Watch the Video:
Supplemental Content:
  • Episode 531: Game Guy - The Unportable Game Boy
  • Link to code: https://github.com/joeostrander/consolized-game-boy
Bill of Material:
SMD Level Shifter SN74LVC245ANSR TEXAS INSTRUMENTS 1 Buy Now
Crystal, 4.194304 MHz, SMD, 11.5mm x 4.7mm, 30 ppm, 18 pF, 30 ppm, ABLS Series ABRACON 1 Buy Now
CAP, 27PF, 50V, MLCC, 0201 MURATA 2 Buy Now
Surface Mount Tantalum Capacitor, 1 µF, 50 V, 1411 [3528 Metric], ± 10%, 6 ohm, B KEMET 2 Buy Now
Raspberry Pi Pico, Microcontroller Board, RP2040, 32 bit, 2MB Flash, ARM Cortex-M0+ RASPBERRY-PI 1 Buy Now
RES, 10K, 0.5%, 0.1W, 0603, THIN FILM ROHS COMPLIANT: YES YAGEO 2 Buy Now
RES, 1K, 0.1%, 0.1W, 0603, THIN FILM ROHS COMPLIANT: YES YAGEO 3 Buy Now
RES, 500R, 0.1%, 0.1W, THIN FILM, 0603 ROHS COMPLIANT: YES YAGEO 3 Buy Now
Surface Mount Chip Resistor, Thick Film, RC Series, 47 ohm, 100 mW, 1%, 50 V, 0603 [1608 Metric] RoHS Compliant: Yes YAGEO 2 Buy Now
Surface Mount Thick Film Resistor, RC Series, 180 kohm, 100 mW, - 1%, 50 V, 0603 [1608 Metric] RoHS Compliant: Yes YAGEO 1 Buy Now
SMD Chip Resistor, 510 ohm, ± 5%, 100 mW, 0603 [1608 Metric], Thick Film, General Purpose VISHAY 2 Buy Now
SMD Chip Resistor, 1 Mohm, ± 1%, 100 mW, 0603 [1608 Metric], Thick Film, Precision PANASONIC 1 Buy Now
Additional Parts:
1 x Super Gameboy Famicom cartridge
1 x NESPi case
1 x Gana VGA TO HDMI
7-pin NES socket1 x
1 x 32-pin SMD GB cartridge slot
1 each x Custom Main Board, Power Dist, and NES Socket PCBs (Designs Available on Github)
1 x  4-Pin SMD 3x4x2.5mm Tactile Push Button (optional)
element14 presents
element14 presents  |  About Andy West |  Project Videos
  • nes
  • nintendo entertainment system
  • raspberry pi pico
  • game boy
  • Game Guy
  • raspberry pi
  • Consolize
  • consolify
  • gameboy
  • mini
  • friday_release
  • pi pico
  • supertazon
    supertazon over 3 years ago +2
    Finally finished building mine with the link port included! Really awesome work by Joe and Markeno! Thanks to Joe for all the troubleshooting! I recorded a video of me playing Kirby: www.youtube…
  • kgal104
    kgal104 over 3 years ago +1
    Would a version compatible with the Gameboy pocket CPU be possible? Looking through the schematic available here: github.com/.../MGB-xCPU.pdf the only major differences seem to be internal vram and some…
  • markeno
    markeno over 3 years ago +1
    This has been a fun project to put together. I added parts to the pcb design to include the Game Link connection. I am waiting on a second Tetris cartridge to come in so I can see if it works. I wanted…
    dougw over 3 years ago in reply to Joe_O
    awesome!
  • Joe_O
    Joe_O over 3 years ago in reply to markeno
    Oh, I had only pushed the Gerber for the version in the video.  The newer SGB cart version should be there now.  I put a newer schematic up too  Thanks for noting that!
    The cartridge slot in the latest version is indeed from the SGB cartridge.  So now you can reuse 4 things from the cart (CPU, RAM x2, Cart slot).
  • markeno
    These are great projects.  I really would like to put one based on it together.  It seems there is a V3 pcb design for "SGB_CART" but no Gerber files for it?  I take it by looking at the pictures, the SGB is a "Stock" or "Salvaged" GameBoy Game slot?  I was also wondering if a complete schematic is available for the V3 board.  As much as I like that case, I think I would like to work it up in something a little bit different.
  • kgal104
    Would a version compatible with the Gameboy pocket CPU be possible? Looking through the schematic available here: github.com/.../MGB-xCPU.pdf the only major differences seem to be internal vram and some pin shuffling, should be fully compatible otherwise
  • supertazon
    supertazon over 3 years ago in reply to Joe_O
    Thank you for your thorough response!
    Yes the idea is mainly to have as few intermediate chips as possible to maintain a high quality video signal. Usually VGA to HDMI adapters can have their issues.
    From my understanding it seems that PicoDVI would be the best course of action in this case! I’d love to look into that but have zero experience in Pico programming whatsoever. If anyone is up to the task it would be awesome!
  • Joe_O
    Joe_O over 3 years ago in reply to supertazon
    That's a really neat project, I might have to try that out.  FPGAs are pretty cool and I'd like to play around with them some more someday.  I really liked that Andy chose the Pico for the original project though -- it's easy to write code for and it's cheap :)
    I'm not sure how much switching to an FPGA would help in this project -- the Pico does a decent job of generating the video signal and the vga2hdmi is super cheap (like $10).  If the goal was to replace the vga2hdmi converter, then an HDMI/DVI transmitter IC could be added to the main board instead.  You could definitely shrink things down a bit more by putting an RP2040 and that directly onto the main board.
    Another video option would be to output HDMI directly from the Pico using the PicoDVI project.  I tried PicoDVI at one point but ran into some issues.  I can't remember what the exact issues were, but I think I was just too much processing time.  It was enough of a challenge for me to combine all the code to be able to run on 1 Pico and maintain timing.  Maybe someone else might be able to get PicoDVI integrated without it breaking.
  • supertazon
    supertazon over 4 years ago
    Terrific project! I am not sure how to contact Joe Ostrander so hopefully he’ll read this. Would it be possible to remove the VGA-HDMI converter middle-man and have a direct DMG->HDMI vidéo signal? It has been done with a fairly cheap FPGA: Tang Nano 4K: https://github.com/Martoni/GbHdmi. It would be the same price overall as while the Tang Nano 4K is more expensive than the RP2040, you don’t need the VGA to HDMI converter anymore. That would be a nice improvement to an already very nifty project!
  • maxpowerr
    maxpowerr over 4 years ago
    I also had an idea to build a Game Boy on a Raspberry Pico. Very cool project.
    DAB over 4 years ago
    I am not a gamer, but I can appreciate the build.
    Well done.
    dougw over 4 years ago
    Pretty slick.
