Project Videos
  • Project Videos
Project Videos
Documents Build your Own Bat Detector with Analog Parts -- Episode 578
  • Date Created: 22 Nov 2022 6:00 PM Date Created
  • Last Updated Last Updated: 25 Nov 2022 8:24 AM
  • Views 31597 views
  • Likes 13 likes
  • Comments 26 comments
This video will show you how to build a bat detector. The bat detector works as a heterodyne receiver that can shift frequencies in the ultrasonic range to range the humans can hear. Using an ultrasonic microphone, you can tune the device to the frequency your bats are using for echo location. As each species uses a different frequency, you could be able to identity the species you are listening to. You can build your own detector, using good old fashion electronics without the use of microcontrollers or sound processing.
Watch the Video:
Supplemental Content:
  • Episode 578 Resources
  • Bat Detector Schematic
  • PCB Assembly Drawing
Bill of Material:
Trimpot, Multi Turn, Cermet, Top Adjust, 200 kohm, Through Hole, 25 Turns Bourns 1 Buy Now
BOURNS POT, LINEAR, 50K, 0.05W, 20%, FLATTED BOURNS 2 Buy Now
MULTICOMP PRO Through Hole Resistor, 1 kohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 3 Buy Now
MULTICOMP PRO Through Hole Resistor, 180 kohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 3 Buy Now
MULTICOMP PRO Through Hole Resistor, 470 ohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 2 Buy Now
MULTICOMP PRO Through Hole Resistor, 1 Mohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Through Hole Resistor, 200 kohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Through Hole Resistor, 62 kohm, MF25, 250 mW, ± 1%, Axial Leaded, 250 V MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Through Hole Resistor, 750 kohm, 250 mW, ± 2%, Axial Leaded, 250 V MULTICOMP PRO 4 Buy Now
VISHAY Multilayer Ceramic Capacitor, 1000 pF, 50 V, ± 10%, PC Pin, X7R, 5 mm VISHAY 2 Buy Now
VISHAY Ceramic Disc Capacitor, 470 pF, 100 V, ± 10%, Y5P, 5 mm, Radial Leaded VISHAY 1 Buy Now
MULTICOMP PRO Ceramic Disc Capacitor, 0.1 µF, 50 V, -20%, +80%, Y5V, 5 mm, Radial Leaded MULTICOMP PRO 2 Buy Now
MULTICOMP PRO Electrolytic Capacitor, 47 µF, 16 V, ± 20%, Radial Leaded, 1000 hours @ 85°C, Polar MULTICOMP PRO 2 Buy Now
PANASONIC Electrolytic Capacitor, 10 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C, Polar PANASONIC 1 Buy Now
PANASONIC Electrolytic Capacitor, 100 µF, 16 V, ± 20%, Radial Leaded, 2000 hours @ 85°C, Polar PANASONIC 1 Buy Now
CLIFF ELECTRONIC COMPONENTS Phone Audio Connector, 5 Contacts, Jack, 3.5 mm, PCB Mount, Tin over Nickel Plated Contacts CLIFF ELECTRONIC COMPONENTS 1 Buy Now
MULTICOMP PRO LED, Green, Through Hole, T-1 (3mm), 10 mA, 2 V, 572 nm MULTICOMP PRO 5 Buy Now
C&K COMPONENTS Slide Switch, SPDT, On-None-On, Through Hole, 6 A, 120 V C&K COMPONENTS 1 Buy Now
Audio Power Amplifier, 250 mW, AB, 1 Channel, 4V to 12V, DIP, 8 Pins LM386N TEXAS INSTRUMENTS 1 Buy Now
TEXAS INSTRUMENTS Operational Amplifier, LM324N 4 Amplifier, 1.2 MHz, 6V, DIP, 14 Pins TEXAS INSTRUMENTS 1 Buy Now
ARIES IC & Component Socket, 8 Contacts, DIP Socket, 2.54 mm, 518, 7.62 mm, Beryllium Copper ARIES 1 Buy Now
ARIES IC & Component Socket, 14 Contacts, DIP, 2.54 mm, 518, 7.62 mm, Beryllium Copper ARIES 1 Buy Now
BUD INDUSTRIES Battery Retainer Clip, PP3 (9V) x 1, Through Hole, Wire Leads BUD INDUSTRIES 1 Buy Now
HAMMOND Plastic Enclosure, Handheld, Plastic, 130 mm, 65 mm, 25 mm, IP54 HAMMOND 1 Buy Now
MULTICOMP PRO Speaker, 500 mW, 8 ohm, 0 kHz to 6 kHz MULTICOMP PRO 1 Buy Now
MULTICOMP PRO Ultrasonic Sensor, Receiver, 16 mm Diameter, 39 kHz, -65 dB, Aluminium, Silver, -35 °C to 85 °C MULTICOMP PRO 1 Buy Now
IF LM386 is not available, you can use the following 2 components: Buy Now
TEXAS INSTRUMENTS Audio Power Amplifier, AB, 1 Channel, 4V to 12V, MSOP, 8 Pins LM386MMX TEXAS INSTRUMENTS 1 Buy Now
ARIES IC Adapter, 8-SOIC to 8-DIP, 2.54mm Pitch Spacing, 7.62mm Row Pitch, Correct-A-Chip Series ARIES 1 Buy Now
Additional Parts:
PCB. You can order it directly from here
You also need a battery
Some wires
element14 presents
element14 presents  |  About Mark Donners |  Project Videos
  • e14p_MD
  • bat
  • heterodyne
  • friday_release
  • ultrasonic
  • echo location
  • donnersm
    donnersm over 3 years ago +2
    Have any questions or suggestions? Let me know what you think! I'll do my best to answer all.
    beacon_dave over 3 years ago +1
    Did you find that there was there much difference in performance between the different ultrasonic sensors in actual use?
  • benkfie
    benkfie 4 months ago
    Hey mate, was working through designing a bat detector using MCU, and thought I'd go analogue first, came across your design so ordered all the bits, got it built, am fine tuning now. Not going to run with a speaker, so just wondering which pads on the jumper need bridging? May have more questions, may not. Having issues with noise, but probably due to powering it with a DC supply rather than a battery! Cheers for the fun project, appreciate your work. (P.S, ordered parts to make ten, guess what all of my family are getting for xmas this year??)
  • michaell1223
    michaell1223 over 1 year ago
    i try to understand how you calculated the amplifier stages.
    how did you calculate the input voltage from the used ultrasonic sensor?
    if i'm correct the 1st input stage has a gain of ~2100 and the 2nd one at max ~260. Which would be extremly high if the input was at 0.45mV.
  • danlindley
    danlindley over 3 years ago
    Hi,
    Is it possible to build this with a LCD read out of the current frequency and with preset buttons to jump to specific frequencies?
  • mpbro
    mpbro over 3 years ago in reply to donnersm
    Any idea how this circuit works with a low bandwidth op amp? I must be missing something but the ultrasound signal frequency is higher than the gain bandwidth of the amplifier section.
    • Vote Up -1 Vote Down
  • v223z3
    v223z3 over 3 years ago in reply to donnersm
    I used headphones and exact same issue. I’m going to check and make sure ground is good and have parts ro build a second board but was hoping to debug issue first. Even on lower volume the amount of screeching isn’t tolerable. Makes me thing it’s not the interference between mic and speaker.You can find a couple of frequencies where it doesn’t do this. See attached photo of board for reference.
  • mpbro
    I am confused about how this circuit can work. The LM324 op amp has a Gain Bandwidth of 1.2 Megahertz. From what I understand, given the amount of gain applied at the first stage this would restrict the bandwidth to less than 10 kilohertz. How are the ultrasonic frequencies able to pass through amplified to the mixer? Also, the type of ultrasonic receiver you specify seems to have a very narrow bandwidth. Have you tested how well it can pick up frequencies up to say 100 kilohertz?
  • donnersm
    donnersm over 3 years ago in reply to v223z3
    Screeching noice is good. It might be feedback from the speaker to the mic. Try isolating the microphone with a cone like shape and don't use speaker but headset. I learned that when using a speaker, lots of feedback is picked up by the mic causing screeching.
  • v223z3
    donnersm  I have no background building circuit boards but I got the components and board and built it. Getting a lot of screeching noises when changing frequency with speaker and headphones. I don’t see any shorts in solder on board. Please advise what may be the issue causing this. I used parts in your BOM from Newark.
  • tmarushak
    tmarushak over 3 years ago in reply to donnersm
    Thank you.
  • donnersm
    donnersm over 3 years ago in reply to tmarushak
    It depends on the opamp you use and the kind op potmeter(lin or log) i would start in the middle and work from there. The jumper is to bypass the speaker amplifier if you planning to use headset only
