Project Videos
  • Project Videos
Project Videos
Documents Enhancing a Magnifying Headband with Auto Sensing Light -- Episode 585
  • Date Created: 12 Jan 2023 4:58 PM Date Created
  • Last Updated Last Updated: 13 Jan 2023 8:24 AM
  • Views 25261 views
  • Likes 8 likes
  • Comments 27 comments
Do you often use a illuminated magnification headband? Do you get annoyed that you need to turn it off and on when looking away from your work? This project contains 2 solutions, a basic tilt sensor option that can be added in minutes, and a more complex distance detecting circuit which will change the illumination depending on how far away the object you are looking at is.
Watch the Video:
Bonus Content:
  • Download Code and Schematics
Bill of Material:
LC1780USB Magnifier, Spectacles & Headband, 1x, 1.5x, 2x, 2.5x & 3.5x LIGHTCRAFT 1 Buy Now
102010328 Arduino Microcontroller Board, SAMD21G18, ARM Cortex-M0+ SEEED STUDIO 1 Buy Now
STMICROELECTRONICS Daughter Board, VL53L0X Gesture and Ranging Sensor, FlightSense STMICROELECTRONICS 1 Buy Now
MICROCHIP Power MOSFET, N Channel, 60 V, 200 mA, 5 ohm, TO-92, Through Hole MICROCHIP 1 Buy Now
COMUS (ASSEMTECH) Tilt Switch, 15 °, 60 Vac, 0.25 A, Nickel COMUS (ASSEMTECH) 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • tilt
  • e14p_KD
  • magnification
  • Xiao
  • Distance sense
  • illuminate
  • modify
  • friday_release
  • hifromkatie
    hifromkatie over 3 years ago in reply to DAB +1
    Thanks, it hard to find the culprit further than "something under the epoxy blob", by bypassing the switch circuit which has the auto power off and other stuff hidden under expoxy, the problem is resolved…
    shabaz over 3 years ago
    I just recently discovered that this kind of thing exists:
    Ultra-thin gooseneck, with M4 thread : )
    image(Image source: Aliexpress)
    I feel this could be key for some sort of lighting solution.
    The hole through it is big enough for a a few very thin wires to pass through (I tested with a couple of lengths of 30AWG insulated wire, but perhaps 3 wires could fit, not much more!).
    I originally got it for a PCB microscope, but as usual, feature creep has occurred and I'm still working on it.
    beacon_dave over 3 years ago in reply to shabaz
    Nice find.
    It looks a little bit like a longer version of the gooseneck mount for an AKG C747 mini shotgun mic.
    https://www.akg.com/Microphones/Speech%20%2F%20Spoken%20Word%20Microphones/2226H00110.html
    Dedolight do some with standard 5/8" lighting spigots on the end.
    Novoflex have some 'MagicStudio' lighting stuff for photography.
    https://www.novoflex.de/en/products-637/desktop-studio-magic-studio/magicstudio-accessories.html
    ...along with a rod support system.
    https://www.novoflex.de/en/products-637/misc-accessories/rod-support-system.html
    I suspect though that there is probably some lab equipment catalogue that is full of this sort of stuff just waiting to be discovered.
    shabaz over 3 years ago in reply to beacon_dave
    Hi Dave,
    Thanks for these links!
    It is really cool seeing what's available in the sound and video world. Those Novoflex rod components look great for making all sorts of decent projects.
    A couple of others that spring to mind from the Manfrotto range are the Dado system:
    https://www.youtube.com/watch?v=PLZV7Zk8NFM
    and the Snake Arm system:
    https://www.youtube.com/watch?v=8M8iPq_ZRWA
    I've used the Dado kits in the past in conjunction with Matthews scissor clamps to suspend the likes of small IP cameras and stuff from false ceiling grids.
