Project Videos
  • Project Videos
Project Videos
Documents DIY Open Source Bluetooth Headphones -- Episode 586
  • Date Created: 17 Jan 2023 3:59 PM Date Created
  • Last Updated Last Updated: 20 Jan 2023 8:24 AM
  • Views 36888 views
  • Comments 41 comments
Dodgy apps, subscription fees, and exclusive phone apps for a pair of headphones? Clem says: no thanks! He's fed up with the shenanigans some manufacturers pull for simple products that should just work. And why change to a different model of headphones when you've found the perfect wired pair? Can't you have that same fit and style, but wireless? So, for this project, Clem sets out to add Bluetooth to some of his favorite wired AKG headphones, using a DFRobot FireBeetle and an I2S audio module. But, to be a true open-source alternative, Clem has to whip up a custom PCB, which doesn't go according to plan. Learn the pitfalls of overly similar part numbers by following his process of figuring out the problem! What Device should have an open source variant in your opinion and would you build it yourself?
Watch the Video:
Bonus Content:
  • Download All CAD and Code for Free!
Bill of Material:
DF robot firebeetle Esp32 DFROBOT 1 Buy Now
Additional Parts:
PCM5100 i2s module
Your favourite wired headphones
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • DFrobot Firebeetle
  • Bluetooth Headphones
  • diy
  • e14_CMM
  • open source
  • I2S audio module
  • friday_release
    beacon_dave over 3 years ago +1
    This was another interesting element14 presents project. Up until now I've been using the likes of Denon or Radial Engineering Bluetooth receivers: https://www.denonpro.com/products/view/dn-200br …
    "...To this end, we have developed the inter-IC sound (I2 S) bus – a serial link especially for digital audio..."
    https://www.nxp.com/docs/en/user-manual/UM11732.pdf
  • mayermakes
    mayermakes over 3 years ago in reply to beacon_dave
    Seems that is the answer but inter intergrated circuit sound would be I2CS then...
  • mayermakes
    beacon_dave over 3 years ago in reply to mayermakes
    Isn't I2CS the plural of I2C though?  Slight smile
    I seem to vaguely recall that Philips originally named it the 'Inter Integrated Circuit' bus back in the 80's, so IIC or I²C.
    Here we have 'Inter IC Sound' bus where 'Integrated Circuit' has already been condensed down to 'IC', so IIS or I²S.
    If it had been 'Inter Integrated Circuit Sound' bus, then I²CS may well have won the day... Slight smile
  • mayermakes
    a kind of recondensation then.
