Project Videos
  • Project Videos
Project Videos
Documents DIY Open Source Bluetooth Headphones -- Episode 586
  • Date Created: 17 Jan 2023 3:59 PM Date Created
  • Last Updated Last Updated: 20 Jan 2023 8:24 AM
  • Views 37413 views
  • Comments 41 comments
Dodgy apps, subscription fees, and exclusive phone apps for a pair of headphones? Clem says: no thanks! He's fed up with the shenanigans some manufacturers pull for simple products that should just work. And why change to a different model of headphones when you've found the perfect wired pair? Can't you have that same fit and style, but wireless? So, for this project, Clem sets out to add Bluetooth to some of his favorite wired AKG headphones, using a DFRobot FireBeetle and an I2S audio module. But, to be a true open-source alternative, Clem has to whip up a custom PCB, which doesn't go according to plan. Learn the pitfalls of overly similar part numbers by following his process of figuring out the problem! What Device should have an open source variant in your opinion and would you build it yourself?
Watch the Video:
Bonus Content:
  • Download All CAD and Code for Free!
Bill of Material:
DF robot firebeetle Esp32 DFROBOT 1 Buy Now
Additional Parts:
PCM5100 i2s module
Your favourite wired headphones
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • DFrobot Firebeetle
  • Bluetooth Headphones
  • diy
  • e14_CMM
  • open source
  • I2S audio module
  • friday_release
    beacon_dave over 3 years ago +1
    This was another interesting element14 presents project. Up until now I've been using the likes of Denon or Radial Engineering Bluetooth receivers: https://www.denonpro.com/products/view/dn-200br …
  • drakulx
    drakulx over 3 years ago
    Hi.
    Great many thanks for this cool project. Now, I want to record the recieved audio and the mic input audio on this bluetooth device end. What kind of board is able to do that , please ?
    I'm thinking, I want to record the incoming audio before it gets converted to analogue and sent to line out. Also the mic audio gets digitised and then I record that.
    So I guess I won't need any ADC or DAC. Just an extension board with microsd support and enough juice to do this audio data saving.
    What kind of board do I need here ?
    Thank you all.
  • mayermakes
    mayermakes over 3 years ago in reply to drakulx
    I don´t know of any ready made board to do that, but you can certainly write a program to save the received data to an sd, card , maybe even do vconversion to a common audio format on board. for recording the mic you will need a DAC and amplifier cicuitry.
  • mayermakes
