Project Videos
  • Project Videos
Project Videos
Documents DIY Open Source Bluetooth Headphones -- Episode 586
  • Date Created: 17 Jan 2023 3:59 PM Date Created
  • Last Updated Last Updated: 20 Jan 2023 8:24 AM
  • Views 37458 views
  • Comments 41 comments
Dodgy apps, subscription fees, and exclusive phone apps for a pair of headphones? Clem says: no thanks! He's fed up with the shenanigans some manufacturers pull for simple products that should just work. And why change to a different model of headphones when you've found the perfect wired pair? Can't you have that same fit and style, but wireless? So, for this project, Clem sets out to add Bluetooth to some of his favorite wired AKG headphones, using a DFRobot FireBeetle and an I2S audio module. But, to be a true open-source alternative, Clem has to whip up a custom PCB, which doesn't go according to plan. Learn the pitfalls of overly similar part numbers by following his process of figuring out the problem! What Device should have an open source variant in your opinion and would you build it yourself?
Watch the Video:
Bonus Content:
  • Download All CAD and Code for Free!
Bill of Material:
DF robot firebeetle Esp32 DFROBOT 1 Buy Now
Additional Parts:
PCM5100 i2s module
Your favourite wired headphones
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • DFrobot Firebeetle
  • Bluetooth Headphones
  • diy
  • e14_CMM
  • open source
  • I2S audio module
  • friday_release
    beacon_dave over 3 years ago +1
    This was another interesting element14 presents project. Up until now I've been using the likes of Denon or Radial Engineering Bluetooth receivers: https://www.denonpro.com/products/view/dn-200br …
  • adamsoileau1
    adamsoileau1 over 3 years ago
    Nice build! I respect all your projects using a custom board and SMD components. (I'm still mainly doing through-hole components myself) Also, was the general volume from the headphones sufficient? I expected to use of amplifiers in most if not all headphones, but now I'm curious about how many wireless headphones actually implement an amplifier or if it's just from the DAC.
  • adamsoileau1
  • mayermakes
    mayermakes over 3 years ago in reply to adamsoileau1
    thanks, I expect most cheap headphones to use purpose built MCUS with integrated DACs . I havent taken apart any commercial offerings so I dont actually know.
    in my experience with these designs the bare I2S module has a very basic amp built in and that was just enough taht I wiuld consider it good.
    about 30% of the board space on my custom board is taken by the actual stereo amplifier (2 caps o nthe back havent even been populated yet).
    So it should be a lot louder. I´d rather have power overhead than to little.
