Project Videos
  • Project Videos
Project Videos
Documents DIY Open Source Bluetooth Headphones -- Episode 586
  • Date Created: 17 Jan 2023 3:59 PM Date Created
  • Last Updated Last Updated: 20 Jan 2023 8:24 AM
  • Views 37413 views
  • Comments 41 comments
Dodgy apps, subscription fees, and exclusive phone apps for a pair of headphones? Clem says: no thanks! He's fed up with the shenanigans some manufacturers pull for simple products that should just work. And why change to a different model of headphones when you've found the perfect wired pair? Can't you have that same fit and style, but wireless? So, for this project, Clem sets out to add Bluetooth to some of his favorite wired AKG headphones, using a DFRobot FireBeetle and an I2S audio module. But, to be a true open-source alternative, Clem has to whip up a custom PCB, which doesn't go according to plan. Learn the pitfalls of overly similar part numbers by following his process of figuring out the problem! What Device should have an open source variant in your opinion and would you build it yourself?
Watch the Video:
Bonus Content:
  • Download All CAD and Code for Free!
Bill of Material:
DF robot firebeetle Esp32 DFROBOT 1 Buy Now
Additional Parts:
PCM5100 i2s module
Your favourite wired headphones
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • DFrobot Firebeetle
  • Bluetooth Headphones
  • diy
  • e14_CMM
  • open source
  • I2S audio module
  • friday_release
    beacon_dave over 3 years ago +1
    This was another interesting element14 presents project. Up until now I've been using the likes of Denon or Radial Engineering Bluetooth receivers: https://www.denonpro.com/products/view/dn-200br …
  • JCRAcoustics
    JCRAcoustics over 3 years ago
    Hey, new to the community here. This was an amazing video! The editing back in time had me laughing away. I'm looking at doing a headphone project and going above and beyond the level of my other projects. I really want to do active noise cancelling which led me to Qualcomm chips. From what I can make out though you have to buy the ANC features as well as the chip itself and to do so you need to be a registered business! It seems a bit of a mine field. Would you have any suggestions for a project with ANC? Would it be possible on an ESP32 or maybe there is a way to use the Qualcomm chips which will probably give the best end product.
  • mayermakes
    mayermakes over 3 years ago in reply to JCRAcoustics
    a lot of manufacturers only sell to "preferred OEMs" so you A have to have abusiness of course but also go through that manufacturers audit. pretty much impossible for a someone just making a prototype. But you may be able to find Devkits or Evaluation boards that already use the desired functionality.
    Active noise canceling is afield I have not tapped into yet,  BUT:
    https://www.analog.com/en/analog-dialogue/articles/audio-noise-reduction-ic.html
    Analog Devices has a chip that could be easier to get.
  • JCRAcoustics
    JCRAcoustics over 3 years ago in reply to mayermakes
    Thanks for the info. I've seen Feasycom also incorporate the Qualcomm chips into a module and there's one that mentions ANC (FSC-BT1057) so I'm going to explore that a bit more too and check it actually comes with the software already on it!
  • JCRAcoustics
