Project Videos
  • Project Videos
Project Videos
Documents Lamptopus: Spinning LED Desk Lamp -- Episode 592
  • Date Created: 1 Mar 2023 7:03 PM Date Created
  • Last Updated Last Updated: 28 Dec 2023 9:49 PM
  • Views 18482 views
  • Likes 18 likes
  • Comments 41 comments
Looking for a fun, low-intensity electronics project for yourself or to share with loved ones? Look no further than Lamptopus! Lamptopus brings light and motion to an articulated 3D printed housing, complete with a top hat. Based around an Arduino Uno and other common hobby electronics components, Lamptopus is sure to bring a smile to those around you and a sparkle to any dark corners in your workbench.
Watch the Video:
Bonus Content:
  • Check out Ruby Zoom on YouTube:  https://youtube.com/@RubyZoom
  • Check out Ruby Zoom on Instagram:  https://www.instagram.com/bigdrillenergy/
  • GitHub and Documentation for NeoPixel + servo compatibility:
    • https://github.com/adafruit/Adafruit_TiCoServo
    • https://learn.adafruit.com/neopixels-and-servos/the-ticoservo-library
Code:
image image
Schematic:
  • SG90 Datasheet
  • NeoPixel Datasheet
  • Arduino Uno Datasheet
Bill of Material:
Arduino Uno Arduino 1 Buy Now
Servo Motor MULTICOMP PRO 2 Buy Now
NeoPixel LED Ring ADAFRUIT 2 Buy Now
Hook Up Wire BELDEN 1 Buy Now
Solder Flux KESTER SOLDER 1 Buy Now
Linear Voltage Regulator TEXAS INSTRUMENTS 3 Buy Now
Multilayer Ceramic Capacitor VISHAY 2 Buy Now
Capacitor TDK 2 Buy Now
Desoldering Braid EDSYN 1 Buy Now
Additional Parts:
3D Printer Filament,Translucent PLA Filament
transparent PLA for lighting up the lamptopus from the inside
9V battery
9V battery holder with on-off switch and solderable leads (already had on hand, amazon)
5V 2A DC power barrel jack for Arduino Uno
Soldering Iron + Soldering Hands / Clips
Hot Glue
Electrical Tape
3D printer, or can use an on-demand print company to get STLs
Have you been paying attention?
You'll gain yourself an achievement and some points if you get it right! Make sure you also leave us a comment below to let us know what you think about the episode.
Lamptopus!
Lamptopus! Watch the Episode 592 of element14 presents Criteria - Answered the question correctly...
Can you answer the following question:
element14 presents
element14 presents  |  About Ruby Zoom |  Project Videos
  • arduino uno
  • NeoPixel projects
  • e14p_RZ
  • DIY lighting
  • hobby electronics
  • Beginner electronics projects
  • beginner circuits
  • friday_release
  • koudelad
    koudelad over 3 years ago
    A fun build to watch. Also, nice to see a new face on element14 presents.
    By the way, Ruby, I would recommend getting Weicon No. 5 wire strippers, you will not regret :)
  • robogary
    robogary over 3 years ago
    Nice Job RubyZoom, keep working on the table pushups. Does the olive oil on the counter help with some soldering projects ?  I am a member of PETAN - People for the Ethical Treatment of Arduino Nanos. Please stop Nano abuse, especially the physical part. Nanos are a sentient device.  Thank you and eat more calamari :-)
  • colporteur
    colporteur over 3 years ago in reply to rubyzoom
    Your explanation of using a code block to control both the servo and LED at the same time reminded me of a story.
    I had built a Nano project and the user wondered why I couldn't ramp up the voltage on a motor and read sensors at the same time. I told them it had to do with the number of squirrels doing the work in a Nano.
    There is only one thread in a Nano doing work. The thread being a squirrel. A squirrel can't gather nuts and drink water at the same time. It eithers drinks water or gathers nuts. The Nano with only one thread to do work can either run the motor or read sensors.
    SBC have multiple cores with multiple threads. Multiple squirrel burrows with multiple squirrels in each burrow. In this configuration some squirrels just gather nuts while other go for a drink and while others are doing nothing.
    My squirrel analogy has helped non-techie types understand concurrency and multitasking without requiring a computer science degree.
    DAB over 3 years ago
    Nice build Ruby.
    Every engineer goes through the same process on their first build.
    You read the books, check for free software then enter the wonderful world of integration, where everything that can go wrong goes wrong.
    As you showed, perseverance is key.
  • kmikemoo
    kmikemoo over 3 years ago in reply to rubyzoom
    rubyzoom   I have learned to connect the two ground (B-) points together on every project.  Maybe it's just superstition, but I have flamed a few less boards this way.  I've also smoked a few of the USB diodes - although I'm not sure why.  They sure are hot when you grab the Nano and go to pull the USB cord out.
  • kmikemoo
    kmikemoo over 3 years ago in reply to charlieo21
    I do some of my best work then - way less overthinking. Laughing
    beacon_dave over 3 years ago
    The top hat 'fascinator' looks like it perhaps could have some sort of interactive function in the future.
    Moving the switch for the servo power on the underside might be one use for it, as might be a rotary speed control or LED control.
    However as the head rotates it might be slightly tricky. Could perhaps use a magnet on the end of a spring-loaded transparent rod to tempt a hall effect sensor on the non-rotating base into a contactless switch, as the servo parks the head in the same place each time.
    Another interactive option for a future build might be to add a capacitive touch sensor ring around the base.
    beacon_dave over 3 years ago in reply to rubyzoom
    Might have to replace the Arduino with a Pi Pico to avoid any confusion Slight smile
  • rubyzoom
    rubyzoom over 3 years ago in reply to colporteur
    Thanks so much for your kind words and suggestions!
    -kitchen was closer ATM. Workbench was a disaster that I didn’t have the energy to clean up at that time.
    -it will take many times.
    -I believe I shuffled across the floor and shocked it pretty good. I also recall dropping it. Sorry Nano…
    -That was my first plan. Decided to change it to use the regulator.
    -you are correct, it was hot! :-) anyways, yes I totally agree there are certainly better suited projects for the regulator and more efficient ways to use the power. It is ok though, Lamptopus didn’t mind. And I got to use a regulator for the first time, which was my main goal!
    thanks so much for watching!
  • rubyzoom
    rubyzoom over 3 years ago in reply to mp2100
    Ooh glad safety glasses are used! Jealous of your built in magnification.
