Project Videos
  • Project Videos
Project Videos
Documents Lamptopus: Spinning LED Desk Lamp -- Episode 592
  • Date Created: 1 Mar 2023 7:03 PM Date Created
  • Last Updated Last Updated: 28 Dec 2023 9:49 PM
  • Views 18484 views
  • Likes 18 likes
  • Comments 41 comments
Looking for a fun, low-intensity electronics project for yourself or to share with loved ones? Look no further than Lamptopus! Lamptopus brings light and motion to an articulated 3D printed housing, complete with a top hat. Based around an Arduino Uno and other common hobby electronics components, Lamptopus is sure to bring a smile to those around you and a sparkle to any dark corners in your workbench.
Watch the Video:
Bonus Content:
  • Check out Ruby Zoom on YouTube:  https://youtube.com/@RubyZoom
  • Check out Ruby Zoom on Instagram:  https://www.instagram.com/bigdrillenergy/
  • GitHub and Documentation for NeoPixel + servo compatibility:
    • https://github.com/adafruit/Adafruit_TiCoServo
    • https://learn.adafruit.com/neopixels-and-servos/the-ticoservo-library
Code:
image image
Schematic:
  • SG90 Datasheet
  • NeoPixel Datasheet
  • Arduino Uno Datasheet
Bill of Material:
Arduino Uno Arduino 1 Buy Now
Servo Motor MULTICOMP PRO 2 Buy Now
NeoPixel LED Ring ADAFRUIT 2 Buy Now
Hook Up Wire BELDEN 1 Buy Now
Solder Flux KESTER SOLDER 1 Buy Now
Linear Voltage Regulator TEXAS INSTRUMENTS 3 Buy Now
Multilayer Ceramic Capacitor VISHAY 2 Buy Now
Capacitor TDK 2 Buy Now
Desoldering Braid EDSYN 1 Buy Now
Additional Parts:
3D Printer Filament,Translucent PLA Filament
transparent PLA for lighting up the lamptopus from the inside
9V battery
9V battery holder with on-off switch and solderable leads (already had on hand, amazon)
5V 2A DC power barrel jack for Arduino Uno
Soldering Iron + Soldering Hands / Clips
Hot Glue
Electrical Tape
3D printer, or can use an on-demand print company to get STLs
Have you been paying attention?
You'll gain yourself an achievement and some points if you get it right! Make sure you also leave us a comment below to let us know what you think about the episode.
Lamptopus!
Lamptopus! Watch the Episode 592 of element14 presents Criteria - Answered the question correctly...
Can you answer the following question:
element14 presents
element14 presents  |  About Ruby Zoom |  Project Videos
  • arduino uno
  • NeoPixel projects
  • e14p_RZ
  • DIY lighting
  • hobby electronics
  • Beginner electronics projects
  • beginner circuits
  • friday_release
    beacon_dave over 3 years ago
    The top hat 'fascinator' looks like it perhaps could have some sort of interactive function in the future.
    Moving the switch for the servo power on the underside might be one use for it, as might be a rotary speed control or LED control.
    However as the head rotates it might be slightly tricky. Could perhaps use a magnet on the end of a spring-loaded transparent rod to tempt a hall effect sensor on the non-rotating base into a contactless switch, as the servo parks the head in the same place each time.
    Another interactive option for a future build might be to add a capacitive touch sensor ring around the base.
